Head gasket blown. Pink/orange tapioca. Have a few questions as to cleanup before proceeding.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by weapon, Jun 22, 2026.
  1. weapon
    weapon Junior Member
    47
    OR
    Backstory: After reading up on here, I have been getting things ready to do the egr clean/replacement maintenance for my two 2010 prius(s). I have collected a bunch of manifolds and coolers from the pick n pull yard and was in the process of cleaning them in my ultrasonic and in various other solution baths. My plan was to keep one extra each on the shelf for the future maintenance. They are all clean as factory new now.
    First car (My boy blue) has had the rougher life, came from the midwest and has 174K miles. Did the first attempt swap but I must have messed something up and it threw a ton of new codes. I think i had a gasket unseat or incorrect torque specs leading to a leak. Took me about a week of rewatching videos to get up the confidence after the first attempt and get it all back together correctly.
    During this exact time, I was driving my second (Big Red) and it has been running perfect coming close to 200k. I was using it as a reference for tube routing, correct bolts and such. That is when I noticed my fluid was orange. Pulled off the cap and it was tapioca (photos). Grabbed the turkey baster and transferred it to a cup. Thick, greasy, and disappointing. There was no overheating, no death rattle on start up, but did get a p0102 the previous day.
    I have watched hours of rebuild videos from all creators (especially the one recommended in the sticky) and think I am ready to start. But none of the videos had my exact situation.
    Here is the questions:
    How do I go about cleaning the goop out of everything?
    Where else will this tapioca be? Inside the radiator? The cylinders?
    Has anyone else run across this style of blowout before?
    #1 weapon, Jun 22, 2026
  2. CR94
    CR94 Senior Member
    2,822
    1,238
    Northwestern S.C.
    Did you acqure 'Big Red" new or used? If used, is there a chance a stop-leak chemical was added to the coolant? Or an incompatible mix of coolant types?
    Brian1954 likes this.
  3. weapon
    47
    OR
    I have had it for over 10 years. Regularly maintained. Never used a stop leak. This is a brand new issue. Always used toyota super long life from the dealership.
    It is def oil mixed in with coolant.
    CR94 likes this.
  4. Mendel Leisk
    42,293
    What were you swapping, engine?
    How long have you had it? Sounds like a stop-leak product. There’s a link in my signature, thoughts on that. (On a phone turn it landscape to see signatures)
  5. weapon
    47
    OR
    was supposed to be a reply. Cleared due to error.
    #5 weapon, Jun 23, 2026
    ASRDogman and Mendel Leisk like this.
  6. weapon
    47
    OR
    I was getting ready to swap egr cooler and clean the manifold in both. I have cleaned extras from the scrap yard.
    Have owned it for over 10 years. No stop leak has ever been in the car.
  7. weapon
    47
    OR
    Dumping the goo from the reservoir. The amount of oil mixed in is crazy. My engine has burned oil for years but it never went into the coolant before.
  8. weapon
    47
    OR
    Safe to assume this goop is all inside my radiator and water pump too? None in the secondary inverter reservoir though (perfectly pink).
    Removed the coolant reservoir and trying to clean as much out of the system as possible.
    Suggestions? What would be a cheap alternative coolant to use for flushing?
    Did pick up a Combustion Leak Detector today to make sure that a blown head gasket is the issue. Only $27 this month at HF.
    #8 weapon, Jun 23, 2026
  9. Mendel Leisk
    42,293
    Water? With say last two rinses using distilled. Then, assuming there's residual water in the systemadd a compatible, full-strength* coolant, 1/2 the system capacity amount spec'd by Toyota, then top up to B line on the reservoir, and run the car in maintenance mode till all hoses are hot (hoses accessible from underside are the last to heat up, indicating thermostat has opened).
    *Note, the recommended Toyota brand coolant "Super Long Life", ONLY comes pre-diluted with water (50/50 in the States, 55/45 in Canada). One full-strenth alternative would be Toyota brand coolant "Long Life", if available. There are likely other full-strength options: I haven't looked into them.
    #9 Mendel Leisk, Jun 24, 2026
    weapon likes this.
  10. weapon
    47
    OR
    Water is good. haha.
    Are the systems (inverter and main) on different loops? The main coolant reservoir was full of the goop so are the tubes leading to it. But the inverter coolant reservoir is clean and fresh. I am unsure at this point on how to check the radiator. Oil seems to be not be affected either.
  11. Mendel Leisk
    42,293
    Yes. Small blessing.
    weapon likes this.
  12. Mendel Leisk
    42,293
    One thing with the (full-strength) Long Life coolant, it's service life is half of the (pre-mixed) Super Long Life coolant. Accordingly, and doubly so considering the mess that's in there now, I'd do another drain-and-fill, with the Super Long Life coolant, at most two years further down the road.
  13. weapon
    47
    OR
    I am still trying to figure out how the oil got in there. haha It is almost 100 today so going to wait for it to cool down a bit.
  14. ASRDogman
    ASRDogman Senior Member
    8,052
    4,083
    I don't think it's oil. Someone put in the wrong coolant.
    Just my opinion...
    If it was oil, it would be a brownish color.
    CR94 likes this.
  15. weapon
    47
    OR
    That would be a welcome theory but I am the 2nd owner and the one person who has maintained it for the past 10+ years. This is the only coolant i have ever put in my prius. Photo 1
    This is what has me so confused. What showed up in the coolant is definitely oil based. You can see the separation of the goop in the milk carton. Photo 2
    I used a pump to suck out as much as I could from the hoses leading to the reservoir. I cleaned that in the ultrasonic and pressure washed until it was free from all goop.
    Would improper coolant (never has been flushed that I know of) make this oily sludge after 10 years of ownership?
  16. weapon
    47
    OR
    Here is the todays update.
    Took off the gooped up reservoir. I cleaned that in the ultrasonic and pressure washed until it was clear. Used a siphon pump to get the goop out of the hoses leading to the reservoir. Then put is all back together and filled it up with just plain water. I drove it around the block a few times and left the car running for a few hours in the heat just to see if any more goop came into the reservoir.
    Tomorrow I will drive it a bit further and run it a bit longer to get a better idea. I will then use the head gasket leak tester to check if I truly have a blown gasket. If that comes up clean, I will flush the system and replace the coolant with Toyota long life and monitor.
    I still need to do the clean egr cooler/manifold swap but I don't want to go through all the work to just find out I have to do a head gasket job.
    Hopefully this is all been just some weird chemical reaction issue from some wrong coolant being in the system from the first owner over 10 years ago. That would be best case scenario.
    Thanks for all the replies so far on this matter.
  17. ASRDogman
    8,052
    4,083
    Don't run just water. You NEED the coolant! Just for clearing it out is fine, I wouldn't drive it though.
    Dump it, when it's cold, and it's still kinda nasty, run water through it again.
    Did you clean the thermostat and coolant pump?
    If oil got into the coolant, a gasket failed, somewhere. Or the head or block is cracked.
    #17 ASRDogman, Jun 25, 2026
  18. Mendel Leisk
    42,293
    If that’s the tester comprising a syringe and solution, it’s testing for carbon monoxide in the coolant, which is not the usual 3rd gen failure mode.
  19. rjparker
    11,030
    6,918
    Mendel is right about this. If you are the only one who could have added sealer or oil in the reservoir you have a problem.
    The reservoir is an active part of the cooling system, its not an old school overflow container. Anything in the reservoir is also in your engine water pump, thermostat, throttle body, heater core, radiator, egr cooler, exhaust heat exchanger and all engine coolant passages including those going through the head gasket.
    Getting it all out will not be easy. I would do at least ten drain and fills with gallon jugs of distilled water, run up to temperature each time to ensure the thermostat opens (monitor flow in reservoir, driving is the fastest way to heat it up) drain and repeat. You only get about half out each time so you are simply diluting the muck (or sealant) with a smaller amount remaining each time.
    After diluting it enough, drain and then fill with Toyota concentrated coolant. It will mix with the remaining distilled water.
    #19 rjparker, Jun 25, 2026
    weapon and Brian1954 like this.
  20. Brian1954
    Brian1954 Senior Member
    2,666
    1,066
    South Central PA, USA
    I did not see it mentioned. Did you check the oil level and condition of the oil in the engine by pulling out the dipstick? I hope you have already done this.
    weapon likes this.
