Head gasket blown. Pink/orange tapioca. Have a few questions as to cleanup before proceeding.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by weapon, Jun 22, 2026.
  1. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    Yes, you made it very confusing.
    Now it's too much to read. :confused:
    Hope that whatever it is doesn't happen again and that you don't have a bad head gasket.
    You should change it BEFORE it fails, when you can decide the time and place.
  2. weapon
    weapon Junior Member
    OR
    Final update (unless the same issue comes back at a later date): Ran all the coolant out until it was just a drip, checked for the goop in the catch container (there was none) and then ran water through it 3-4 times just to make sure it was fully flushed. Refilled, changed out the egr cooler and cleaned intake manifold.
    Now a few more issues not pertaining directly to the coolant but that will be on another post as this one is a bit confusing for some.
  3. Mendel Leisk
    42,379
    Please, stick to the same thread.
  4. weapon
    OR
    Nah. This thread is done and the coolant problem has nothing to do with any of the other issues.
  5. weapon
    OR
    Final Final update. Got her into maintenance mode and ran it through its paces. There was still some residual pink goop that ended up back in the reservoir after. So i clamped the lines, cleaned the reservoir in the ultrasonic and reinstalled. Repeat the process and now it is the correct shade of pink. Crisis averted or just postponed? Time will tell.
  6. ASRDogman
    8,070
    4,092
    Well, you thought you got it all out, but it got flushed out.
    Soooooo.......
    It's just pooling in the reservoir. It's throughout the system.
    Until you clean/replace every hose and part in the coolant system, it likely won't go away.
    Doing what you're doing, eventually, you'll have flushed it enough, that it will eventually be cleared out.
    It all depend on how many time you want to do what you are doing.
    I believe Toyota has a coolant flush. Perhaps you should use that, then flush that out and fill with the
    Toyota 50/50 coolant???
  7. rjparker
    11,144
    6,986
    Third time is the charm? Remember the coolant reservoir is an active part of the coolant circulation as soon as the thermostat opens. As a result any contamination is quickly distributed through everything including the heater core regardless of heat or cool settings at the time. When driving it takes about 5 minutes for full circulation to begin.
    Toyota coolant is made to prevent internal corrosion and clogging. It has a role in protecting gaskets and seals including the head gasket.
    Since a coolant system drain and fill leaves about half the fluid each time, I have seen shops do multiple drain and fills using distilled water with the car driven each time to dilute the contamination (usually sealer) more each time. Maybe ten drain, fills and drive cycles. All done in one or two days.
    At that point, one more drain followed by a fill using straight Toyota concentrated coolant. From then on, 50k mile drain and fills each time using standard procedures.
    #47 rjparker, Jul 2, 2026
  8. rjparker
    11,144
    6,986
    If I were a betting man, I would put money on a head gasket issue assuming no one was punking you by directly adding oil into the coolant.
    However, your situation is unique in my memory over the last twenty years of Prii interests. Which is the reason you did not get absolute assurances that you had a fluke of nature. Plus we were not in front of it with a borescope and coolant system pressure tool.
    We would all love to get assurances that a simple and low cost solution is all we need. Perhaps you also wanted simple clarity when you expressed some mildly snarky (frustrated?) comments along the way. Of course you could always ask for your money back and get a full Priuschat diagnostic refund instantly. The dealer or other pro shop would have diagnosed faster and more accurately but refunds of their time never happen even if they are proven wrong. On a forum you will get conflicting advice; it's the real cost of a free consulting service.
    If the contamination was immaculate conception* with no human skulduggery, perhaps the prophesies are getting ready to happen. If not we will wait for another update which would not be uncommon on a gen3 Prius of a certain age.
    *loosely defined
    #48 rjparker, Jul 2, 2026
  9. weapon
    OR
    That is the plan as I will be continually monitoring. I have not run it through any long term driving paces yet so we will see. I am sure there will be more particulates that come to the surface. If so, I will rinse and repeat the process as it only take a few minutes to uninstall and then a couple hours in the ultrasonic cleaner. I will probably hit the junk yard and grab a second reservoir to allow me to swap more quickly in the future of this process.
    I have not written off that it might still be a head gasket (i have the rebuild kit on the shelf if it comes to that) as this contamination has to be coming from somewhere. But as of now, no codes, never overheating and running smooth with the newly cleaned egr cooler and manifold.
  10. weapon
    OR
    The coolant flush from Toyota is a good suggestion though. When they have a sale, I will hop on that and get it done.
    As for now, I will keep going with this incremental method. The particulates that showed up the second time were minimal, unlike the first goop cleaning as one would expect. Maybe it is a continuous small trickle from a bad head gasket that will build up over time or it was some other unknown contamination years in the making that I never noticed. If it comes back fully and quickly then we will know that I have a more serious issue that will need to be attended to.
