Is There A Best Case Scenario Which Minimises Carbon Build Up In EGR Circuit?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by richard1540, Jun 29, 2026.
  1. richard1540
    richard1540 Junior Member
    27
    Australia
    i-Tech
    Just wondering what is the best driving style to minimise carbon build up in the EGR circuit?
    Sustained Freeway/Highway driving vs City stop and start?
    Higher octane gasoline (petrol) (91-92 (95 RON in Europe or Australia)) or (94 (98 RON in Europe or Australia)) or an Ethanol blend?
    Anything else?
    I’m in Australia and my 2011 Gen 3 has 106,000 miles (170,000 kms). I’ve been trying to find a mechanic to to take the EGR cooler pipe to see if there’s a build up but they don’t want know about it given the work to get at it. I have done mostly highway/freeway kilometres and always use 91-92 or 94 gasoline. The fuel lid specifies 95 (91-92) minimum and that it is ethanol compatible ( which i’ve never used).
    #1 richard1540, Jun 29, 2026
  2. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    It's a waste of time to look at that huge pipe. The cooler is what clogs. Those passages
    are small. Same with the intake manifold.
    Changing the oil/filter at 5000 miles helps, not driving the Prius like an F1 car helps.
    Installing an oil catch can helps. Nothing will stop it, it's a by product of engines.
    Highway miles are better for the Prius then city driving.
    Using a higher octane than what Toyota calls for is just wasting your money. It's not going to help
    the engine at all. Quality of the fuel will.
  3. Mendel Leisk
    42,377
    Just clean it. Shouldn't have to be, but Toyota screwed the pooched, and doesn't want to own up.
    Merkey and bisco like this.
  4. rjparker
    11,144
    6,986
    The op said he can't find a shop that wants to do it.
    The best approach is to keep your 2011 from burning oil. Oil burned through the combustion chamber creates excessive carbon which clogs up the catalytic converter and will fully clog up the egr cooler.
    If it is already burning oil (which is most common after 125,000 miles) the engine needs revised pistons and rings. This problem was acknowledged by Toyota years ago and changed free if oil burning became excessive while still in the powertrain warranty.
    Many of us simply view the automatically calculated egr flow on a regular basis:
    A good egr flow is typically 18-22.
    This comes from the bluetooth phone app "Car Scanner" or other obd2 scanners including Techstream. The car will code if this periodic test fails.
    Another easier to achieve egr related maintenance is to have a shop replace the intake manifold which may be the only credible egr flow clogging concern.
    If head gasket issues are the real concern, the egr cooler clogging theory is not shared by Toyota, their mechanics and apparently your guy.
    If existing stumbles and rough running are your concern, an egr block flow test is easy for your shop to accomplish and can determine if the egr valve is sticking open, a failure mode that sometimes happens and was also covered by Toyota for a period.
    Egr block flow test
    A revised egr valve is available as well.
    Valve Kit With Gaskets
    04004-58137 - Toyota Parts Deal
    #4 rjparker, Jun 29, 2026
    Brian1954 likes this.
  5. CR94
    CR94 Senior Member
    2,840
    1,245
    Northwestern S.C.
    1) Minimize oil consumption;
    2) Minimize conditions that lead to burning a rich fuel-air mixture while EGR is active.
  6. Mendel Leisk
    42,377
    And install an effective oil catch can.
  7. richard1540
    27
    Australia
    i-Tech
    It only just started using oil. Not much. Maybe 8/10 of a pint (500ml) over 6000-7000miles. I’ve used 0W-20 synthetic oil over the last couple of oil changes and i put it down to the thinner oil getting past the rings. Previously the Toyota dealer used 5W-30 semi synthetic.
    I had planned to buy a new EGR valve, EGR cooler, the pipe, gaskets and whatever else needed to be cleaned and just have a mechanic replace them.
    We have a lot of diesel 4WDs here in Australia. A plague of them. They have the EGR and DPF issues after they get to a certain age. Most of the owners just blank/disable the EGR and possibly the DPF. It’s illegal and $AU11,000 fine if they get caught and prosecuted but the owners generally decide which government gets elected so they get left alone.
  8. Mendel Leisk
    42,377
    Just editorial: an imperial pint? A full US pint is roughly 473 millilitres (Google ml in a pint). Maybe just stick to litres lol.
    again, it’s conflation to think that no oil consumption equals no EGR clogging, a tight engine still puts out carbon. The 3rd gen EGR design is the main problem: it’s undersized, gets its exhaust gas upstream of the catalytic converter, and consistently clogs up. It’s very evident Toyota did not test it properly, before going to production. The revisions in 4th gen EGR design illustrate what they missed.
    I wouldn’t go there with the Prius, if that’s the thought. My 2 cents: maintaining it, keeping it clean and functional, is the way to go. “Blank/disable” is equivalent to “clogged”.
    With 106k miles, it’s all eminently cleanable. The only thing I’d even entertain replacing is the cooler, but that’d come clean in a few hours with a series of potassium hydroxide solution soak-and-rinses (10~15% by weight, KOH to water, following safety guidelines), which can be happening while you’re dealing with the rest, which is doable with brake cleaner, rags and brushes.
    you can easily bang this out in a weekend, with no replacement of components.
    Second time around I splurged, replaced the intake manifold gaskets, around $35 CDN IIRC.
    #8 Mendel Leisk, Jun 30, 2026
  9. ASRDogman
    8,070
    4,092
    See if you can find a used oil cooler from a junk yard.
    There are no moving parts, and it's stainless steel.
    Oven cleaner and a pressure washer does a good job of cleaning it out.
  10. rjparker
    11,144
    6,986
    Egr cooler. Buying new online is not too bad as the prices have come down over the years. There are no aftermarket or counterfeit egr coolers to worry about.
    You may get a significantly lower price since you don't have our excessive import taxes.
  11. CR94
    CR94 Senior Member
    2,840
    1,245
    Northwestern S.C.
    So it's a miracle that mine, among others, isn't clogged, even at considerably higher mileage than richard1540's has?
    Didn't all EGR systems of every model and brand before the 4th-generation Prius obtain their exhaust gas upstream of the catalytic converter?
  12. Mendel Leisk
    42,377
    That’s heartening. What’s the miles, and you’ve checked it, say the cooler?
    First I heard about was gen 3, and yes it’s upstream.
  13. CR94
    CR94 Senior Member
    2,840
    1,245
    Northwestern S.C.
    See signature for odometer number. Still scoring ~19kPa in the automated Mode 6 test result for EGR status. I doubt I'm the only one.
    Automotive EGR systems have been taking exhaust from upstream of catalytic converters since at least the late 1970s---long before any Prius existed.
  14. rjparker
    11,144
    6,986
    Excessive oil burning will absolutely clog the cooler with a solid gummed up mess no cleaning product or lye will fix. It will also code when the egr flow test fails.
    A non oil burner will simply add a small coat of carbon to the cooler which does not significantly reduce flow.
    Focusing on the intake manifold has some Toyota support. Toyota revised the intake manifold on several occasions making an updated version a reasonable expense on a car with high miles.
  15. Mendel Leisk
    42,377
    Seeing is believing.
    I'm sceptical, that there's near-nill carbon until you start burning oil. Too, flow rates aside, how do you quantify the cooling ability of the "cooler", with close to a mm of carbon on the internal fins. Or judge how uniform the flow is, in the intake manifold's EGR capillaries, feeding individual cylinders.
    Too, if I'm overly caution, that's ok, I'd rather err on the side of caution; don't relish pulling the head. I suppose I'm being abrasive, but I'll take that over complacency.
    ETC(SS) likes this.
  16. 20113rdgen
    20113rdgen New Member
    New Zealand
    The important thing is to clean the egr passages on the intake as well.
    The head gasket on these cars commonly fails between cylinders 1 and 2, as these cylinders receive less recirculated exhaust fumes do to the intake design.
    Mendel Leisk and CR94 like this.
  17. CR94
    CR94 Senior Member
    2,840
    1,245
    Northwestern S.C.
    Yes, especially when the EGR ports for those cylinders clog before the others or the cooler, resulting in imbalanced EGR delivery..
