TOYOTA Prius V AUX USB INPUT PORT P/N 86190-48030
Discussion in 'Prius v Audio and Electronics' started by Air_Boss, Aug 1, 2024.
  1. Air_Boss
    Air_Boss Senior Member
    4,241
    1,192
    New Yawk
    Any one know whether the TOYOTA Prius V AUX USB INPUT PORT P/N 86190-48030 installed in the lower front console has an integral fuse or fusible link? Not getting power or connectivity to head unit. Thanks.
  2. rjparker
    10,920
    6,853
    No fuses likely but you could ohm out the wires. I give it 95% no internal fuse as Toyota and everyone else typically current limits usb charging power.
    It appears half of the wires go to the ext box and the other half go to the head unit.
  3. Air_Boss
    4,241
    1,192
    New Yawk
    Thanks. Guess I need to break it down again.
    In your photo, which connector goes to the console USB module?
  4. rjparker
    10,920
    6,853
    First, I assume your car originally was cabled for a 57011 head unit with an ext module. So the cabling should be the same. But there is one cable that could go to the head unit or the extension module.
    Here are some pics of the wiring.
    Note the cable in between the two boxes.
    And a pdf on how to add an ext module
  5. Air_Boss
    4,241
    1,192
    New Yawk
    Yes, a 57011, on which I swapped out a failed YY050 extension box for a known working (and does, on APPS, MAPS, NAV, BLUETOOTH) and replaced all existing harnesses as were, but no USB connectivity or power before or after.
    Which is the USB harness in your photo of the backs of the Siamesed units?
    Thanks .
  6. Air_Boss
    4,241
    1,192
    New Yawk
    Wiring, as is.
    #6 Air_Boss, Aug 1, 2024
  7. rjparker
    10,920
    6,853
    Apparently the cable and usb input port
    #7 rjparker, Aug 1, 2024
    Air_Boss likes this.
  8. Air_Boss
    4,241
    1,192
    New Yawk
  9. Melthias
    Melthias Member
    109
    37
    Southern Maine
    Two years later, but I am wondering if you ever solved the issue @Air_Boss? I just got a prius v 2012, and do not have USB power or connectivity. I got another head unit (from a 2016), but still no USB. I decided to cut the USB wiring coming from the head unit to test for voltage. Only a few millivolts. I also have tried a different harness on the rear of the radio, still with no 5V power.
  10. rjparker
    10,920
    6,853
    You did not say which mfd model you have. Most of the time its a 57011 with an "external" module (mounted on the bottom of the mfd) which connects to the usb port. If the external module fails you lose usb connectivity.
    As I recall, some have disconnected the external module and reconnected the usb harness cable directly to the mfd with success.
  11. Melthias
    Melthias Member
    109
    37
    Southern Maine
    The car came with a 57011, and I read on here about installing a radio from the facelift years. I bought and installed a 510057. That one only has one connection point for the USB, which is in the main body of the radio. I may try what you suggest, and hook up the original radio but without the extension box to see if the USB will work, and if so then I guess I bought a faulty facelift unit.
  12. Air_Boss
    4,241
    1,192
    New Yawk
    Never solved it. Replaced the Harmon box which solved another problem, but the USB never came back. I still consider a 510057 swap, but at this point, don't use the car enough to warrant the effort.
  13. Melthias
    Melthias Member
    109
    37
    Southern Maine
    I tried putting the old 57011 one back on and disconnecting the extension box, with the USB connect do the main box. No difference unfortunately! Still no USB. I will try returning the 510057 and getting a different one.
    Do you know if there are any sound differences between the 510057 and the non-NAV version for the facelift? We never use navigation or XM radio.
  14. rjparker
    10,920
    6,853
    . Then its most likely the cable shown in posts 2 and 7. The 4 wires number 1-4. I would ohm them out.
    The usb a standard pin outs for power and ground. I would verify power to pin 1 and to chassis.
    There are three fuses involved but I think other things would be out. Worth checking.
  15. Melthias
    Melthias Member
    109
    37
    Southern Maine
    (I would post pictures, but my phone is currently broken)
    So, I cut the cable about 1inch from where it plugs into the radio. This way I can get a more direct read on the voltage coming out of the unit. When checking the red and black wires I should get 5 volts, but only get like 900mV. This is the case in every combination I have tried, between two radios and two harnesses (the Ebay radio came with a cut off harness).
    In my mind, this would only happen from a bad radio, bad connector, or if there is not always 5V between the two power leads.
    I have checked all the fuses under the hood, and they are all intact. I think I have also checked the ones under the dash, but I can't say for sure. As you say, I suspect that any blown fuses would make something else not work.
  16. rjparker
    10,920
    6,853
    All I can tell you is my 2012 v with a 57011 has a usb port that charges. Normally I use bluetooth for other phone to radio audio. Of course my system still has a functioning external module with nav, etc so the cable is plugged into the ext module.
    I would not rule out a short in the cable or one of the connectors which would kill the 5v. Normally I would expect the output to protect itself with current limiting.
    The easy step is to replace that cable.
  17. Air_Boss
    4,241
    1,192
    New Yawk
    Any way it could be the panel mounted AUX/USB jack itself?
  18. Leadfoot J. McCoalroller
    8,252
    7,754
    Pennsylvania
    2018 Prius c
    Absolutely- the contacts are meant to be self-cleaning with repeated insertion and disconnection, but you can get some schmutz or lint in there that prevents a circuit. You can check for power on the pins of the harness feeding it.
    You could also lop the end off of an unneeded USB cord or device and use it to make up a testing harness to check continuity through the dash connector.
