Better YET, how many miles on the CAR? Depending on the history for a '14 (137 months?) you might be due for some significant maintenance. If those records are not available I would presume that none maintenance items have been done and proceed thusly: Warranty and MAINTENANCE guide is HERE: Toyota Manuals and Warranties | Toyota Owners https://MAINTENANCE GUIDE.pdf NOTE!!! There are some lots and lots of dealer recommended "maintenance items" that are NOT necessary.....and perhaps some Necessary (IMO) items that are not necessarily dealer recommended..... Good Luck!
Thanks. I did not know that. I am still reading all of the manuals that came with it. I just got back from the insurance office; it’s now fully insured. Okay. I just ran another OBD check using the standalone Autel AL629 reader. No stored nor hidden codes. I just got the Veepeak dongle in the mail this morning. I will use that with the Dr. Prius app. This morning, I also ordered the AP200 dongle from Amazon. I am going to buy Toyota 50/50 pink coolant to have in the vehicle in case of emergencies. I checked the oil, it looks honey gold in color, so it has probably been recently changed. For motor oil, maybe buy Valvoline Restore and Protect 0W20? Or use what I have already, which is Costco Kirkland 0W20?
The car has a lot of miles: 177K. According to CarFax, it had 158K in August, 2024. This same independent dealer put in a new head gasket and new head, new water pump in November 2024, and new brake pads and rotors this past February. An AutoCheck and NHTSA check showed no outstanding service recalls on this vehicle. But, maybe I should have a Toyota dealership look at it.
Depending on what part of Caly you call home, one of your fellow forum members might be able to recommend a good independent shop. You mentioned some coverage from the dealer which might be worth 'something.' Best!
Yeah, an independent shop is always a better choice than a Toyota dealer, once the factory warranty is out. Some of them know the car better than the dealer and all of them charge less.
We are in Southern California for now. Two of our best friends own Prius v’s, and they both use the same independent shop. In addition, HybridPit is also a service option; they are about 8 miles away from us, I am excited to have a car that gets decent gas mileage and can still haul stuff when needed, without hauling too much of itself. In contrast, our gas guzzling minivan weighs 6050 lbs empty, so no wonder it only gets 18-20 combined mpg. I should qualify what I wrote earlier about the car’s mileage. The Carfax report printed and dated 6/16/2026 says the car has 158900 miles but this nearly matches an earlier odometer reading (158679) from July, 2024 state inspection. At the dealer lot, the Prius’ odometer read 177437 on the day of the Carfax report was printed. So, somehow Carfax was off in its odometer reporting. I assume that these are miles and not kilometers.
Sounds like the carfax report has the wrong date. Carfax is far from accurate. Costco oil is fine. The dealer is unlikely to tell you much if the car drives straight and runs smooth. They really can't predict problems that don't code first. At this point you need to drive the car quite a bit and check the rate of oil use, if any. Watch the passenger coolant reservoir level. Plus get a handle on the brake booster cycling while the independent dealer / mechanic is on the hook for a one year warranty.
