Just did head gasket, now won't start
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by snakeil, Jun 30, 2026 at 11:40 PM.
  1. snakeil
    snakeil New Member
    Tuesday
    Iowa
    2012 Prius V, 200k miles, just DIYed the head gasket replacement and intake manifold and EGR cleaning with help from everyone here. EGR cooler was completely blocked, so were passages to cylinders 1 and 2. So much oily carbon in the intake. Everything is assembled and i wanted to enter maintenance mode to get air out of the cooling system, but I'm at an impasse. Turns out it won't start at all.
    The whole thing did take about 4 weeks, between getting the head back from the machine shop and doing this a few hours at a time, so the HV and 12V batteries were disconnected the whole time. According to Dr. Prius, the HV battery is at 53% state of charge. There were code in Dr. Prius and OBDLink, I'll try again tomorrow and share screenshots.
    12V battery was around 11.6, and i wrongly assumed it would charge leaving the car in what I thought was ready mode, but it drained itself.
    Connected to our pickup's battery with the truck idling, got the 12V up to 12.7. Trying to start still just shuts down the car. Start button is orange, then with foot on the brake it's green, but when you press it, the dash goes dark except for the mileage and a flashing car with lock at the bottom right. 12V systems all seem to work. Fob battery was 2.88V, so replaced it with new, but still no better.
    At first I thought I was doing a bad job of the maintenance mode sequence, but there's something else. Park seems to work, neutral seems to work, the car will roll. Turning the crank by hand (ratchet) spins freely. 12V systems seem to work, but there's no starting the car.
    I did find an aftermarket remote start module wired into the car, but I'm hesitant to remove it since before I took everything apart, the car did run. We did not know this module was even in the car. 20260630_175916.jpg 20260630_175920.jpg
    Current plan is to disconnect the 12V battery for 5 minutes, reconnect, and check codes. Any other ideas?
  2. ETC(SS)
    7,475
    Bump.
    I was thinking that the car sat idle for over a month with a parasitic draw on the Aux battery and that 12.7 is too low for the 12v battery while in "Ready" mode but reading through a few 'no start-12VDC ' posts now makes makes me wonder about that.
    snakeil likes this.
  3. snakeil
    snakeil New Member
    Tuesday
    Iowa
    Ok so I checked codes this morning and the HV battery code was P0A0D. First YouTube link was basically my only problem. Slid the connector into place, cleared codes, and car started as expected. Hope this helps everyone else. Here's my screenshots, I expect (hope) some of these codes clear once the engine has run a few cycles.
  4. Mendel Leisk
    42,231
    ^ is that etc, or site shenanigans? (sounds like OP)
    thoughts:
    1. 12-volt battery depleted
    2. PCV hose not connected (resultant vacuum leak will stop engine immediately)
    3. Hybrid battery safety switch not properly reinstalled
    #4 Mendel Leisk, Jul 1, 2026 at 9:24 AM
    snakeil likes this.
  5. snakeil
    snakeil New Member
    Tuesday
    Iowa
    It was definitely #3. Immediately showed the "READY" light when it had not before. Engine turned on and ran, minimal excitement except for sweet relief. Only other excitement so far has been a fuel rail leak that I can address tonight. I may have pinched one of the O-rings during the install. Thanks!
  6. rjparker
    10,957
    6,873
    Very common rookie mistake
    snakeil and ETC(SS) like this.
  7. ETC(SS)
    7,475
    Rooks usually leave HG replacements to the pros.
    WELL DONE so far.
    Don't forget to fill us in on the next chapters!
    snakeil likes this.
  8. snakeil
    snakeil New Member
    Tuesday
    Iowa
    Wasn't the only one either. I neglected to verify if the Fel-Pro gasket kit even came with the o-rings (it didn't) and that's why I reused the originals. And same with the EGR pipe to intake, the little vvti gasket and the o-ring under the valve cover. I've been wrenching for the better part of 25 years, mostly out of necessity, and there's always something silly. This was my first head gasket, and first hybrid vehicle.
    That said, after the first few run cycles, the codes for intake phasing, MAF and intake temp low voltage have not returned. The part I'm most pleased with is no leaks, and the only extra parts were the nut and stud that held the bottom of the EGR cooler.
  9. Mendel Leisk
    42,231
    Toyota's rebuild kit is the way to go. Fel-Pro's basically a custom head gasket, and a partial collection of "this'll do" peripherals.
