Has anyone used the Autel MaxiAP2000 to bleed brakes post actuator-swap?
Discussion in 'Gen 2 Prius Main Forum' started by priuslyfe, Jul 2, 2026 at 9:31 PM.
  1. priuslyfe
    priuslyfe Member
    328
    70
    I swapped the actuator but have not driven it yet because trying to find the best way (read: simplest) to bleed the brakes. I don't have techstream nor a laptop. However, I do have the Autel app which has a actuator-swap function for bleeding brakes. There doesn't seem to much direction online on to use it though.
    thoughts appreciated.
  2. ChapmanF
    18,923
    I haven't used it post actuator-swap, but I've used the same bleeding function in the Autel that you'd use for that, and it worked.
    Techstream actually has two bleeding routines: a shorter one for routine things like changing a caliper, and a longer one in case you worked on the underhood bits (bit of overkill for the routine jobs). The shorter one is the one my AP200 doesn't have; it seems to just have the longer one.
  3. priuslyfe
    priuslyfe Member
    328
    70
    thanks.
    I've researched it to death and there seem to be several ways that people have reportedly had success. However, some say in the end they had to get techstream, so I've been dissuaded from starting. Using Autel doesn't seem as common.
