Lately I've noticed oil drops on my driveway and I looked underneath and it looks like it's all concentrated around the oil pressure sensor. Could this be the reason for the oil leak? Here are a couple of pictures.
The housing of the sender uses a gasket that surrounds the plastic of the expectrical components of the sender. The gasket appears to have developed a leak. The metal body of the sender is made of thin metal and can be easily deformed if not installed with a special oil sender socket.
I'm wondering if a socket with a 3/8" drive would be easier to get into the confined space versus a half inch drive? I see 24mm deep sockets are typically used to remove the oil pressure switch but most come with a 1/2" drive and it's just that larger ratchet will be harder to maneuver in that limited space.
You could add a 1/2"-to-3/8" adapter, but that will add length. Maybe that's good anyway; you want to use an extension? Repair Manual info in attached:
While waiting for Amazon to deliver the 24 mm deep socket tomorrow, after removing the passenger side front wheel and that little panel I was able to access the oil pressure switch very easily. I was able to remove it without any problem using a crescent wrench. So since I can't use a torque wrench until tomorrow to double check the tightness, should the threads disappear or should some still be showing after installing the new switch? **Also, in the linked pdf it states that after installing a new pressure sensor switch you should not start the car for at least an hour. There was no reason indicated so I'm wondering why you should wait an hour before starting your car?
I just used a spanner.. Replaced and fired it up no problems... Never heard of not starting for an hour Posted via the PriusChat mobile app.
The earlier step in the instructions is to put Three Bond 1344 on the new sensor threads. The hour after installation is for the 1344 to set before putting oil pressure on it.
Ok, that makes sense, but the replacement sensor I bought from autozone already comes with that white thread locker tape on it. Not sure but it looks like teflon. Seems to be doing the job as no leaks detected after 3 days.
I am just now having this problem. Where did you get your part? Were any threads showing after install?
Be super careful installing. That's a tapered thread, so overtorquing the sensor almost guarantees a cracked block.
My 2013 Toyota Prius is having that problem too. Some oily sludge got on its electrical connector as well.
Typically its the timing chain cover sealant just above the oil pressure sensor. A bib job. However the sensor can be changed by removing the right front (passenger) wheel and a small access panel. As noted above, do not over tighten.
Drips around the oil pan seams "might" originate from a leak up higher. Wiping everything and monitoring helps pinpoint.
I found strong evidence of oily sludge in my car's engine when I took off the oil fill cap. And a small amount of copper corrosion in my car's ignition coil boots. Problems that are NOT more trouble than it's worth to do myself, but will destroy my car's engine if not promptly addressed.
