Has anyone used the Autel MaxiAP2000 to bleed brakes post actuator-swap?
Discussion in 'Gen 2 Prius Main Forum' started by priuslyfe, Jul 2, 2026 at 9:31 PM.
  1. priuslyfe
    priuslyfe Member
    331
    70
    I swapped the actuator but have not driven it yet because trying to find the best way (read: simplest) to bleed the brakes. I don't have techstream nor a laptop. However, I do have the Autel app which has a actuator-swap function for bleeding brakes. There doesn't seem to much direction online on to use it though.
    thoughts appreciated.
  2. ChapmanF
    18,939
    I haven't used it post actuator-swap, but I've used the same bleeding function in the Autel that you'd use for that, and it worked.
    Techstream actually has two bleeding routines: a shorter one for routine things like changing a caliper, and a longer one in case you worked on the underhood bits (bit of overkill for the routine jobs). The shorter one is the one my AP200 doesn't have; it seems to just have the longer one.
    PriusCamper likes this.
  3. priuslyfe
    priuslyfe Member
    331
    70
    thanks.
    I've researched it to death and there seem to be several ways that people have reportedly had success. However, some say in the end they had to get techstream, so I've been dissuaded from starting. Using Autel doesn't seem as common.
  4. ChapmanF
    18,939
    If I were to swap my actuator, I would follow that by using the existing long-form bleed procedure in my Autel AP200 that I have already successfully used.
  5. PriusCamper
    PriusCamper Senior Member
    13,380
    5,407
    Pacific Northwest, USA
    How long does the longer one take?
  6. ChapmanF
    18,939
    Mostly down to how quickly you can shuttle yourself around to the various bleed screws.
    On my gen 3, it'll send you around in some order (I forget the order, which is fine, because it prompts you) to each rear caliper, to each of the front calipers, to each of the front calipers again (there are two different hydraulic circuits serving the front calipers, both need the air out), and to the bleed screw on the stroke simulator. Then it'll empty and re-pump the accumulator half a dozen times, and finish up by learning the linear solenoid offset.
    Recognizing this is a gen 2 thread, I have to admit I haven't had occasion to use the AP200 for this procedure on a gen 2, so I can't say what details might be different there.
  7. priuslyfe
    priuslyfe Member
    331
    70
    So you had to have ALL the wheels off for the Autel method? it seems that without it, using shade tree techniques, you don't need all wheels off...either fronts or rears.
    also how difficult was it for a first timer???? almost considering towing to a shop to bleed because although the actuator swap isn't that hard, I know that bleeding there is somewhat more of an art to it.
  8. Tombukt2
    13,788
    2,497
    You don't have to have the wheels off to bleed the brakes it makes it easier to access the parts wheels off . You can be be on ramps up front and nothing in rear. I've used the ap200 a lot to bleed the brakes because it keeps me from getting a complete laptop and cabling off the shelf and making sure that it's charged. the Ap bleed menus mimics tech streams .
    priuslyfe likes this.
  9. ChapmanF
    18,939
    I can reach all four bleed screws on my gen 3 with no special effort, all four wheels on the ground. Maybe if my arms were very short it would be different. For the front, turning the steering to one side and the other makes it easy.
    Gen 3 has a fifth bleed screw on the stroke simulator, which (on a US car) can't be reached without removing the windshield wipers and cowl. I do that work before starting the bleed process, so I don't have to take time for it during the process while draining the battery.
    If I remember right, gen 2's stroke simulator is in a different place. Having not worked through this procedure on a gen 2, I'm not sure if there are more bleed screws under the hood to be found.
  10. PriusCamper
    13,380
    5,407
    I bet alot of people in our country are experiencing a stroke simulator right now.
  11. priuslyfe
    priuslyfe Member
    331
    70
    thanks.
    some of the youtubes Ive watched have at least 2 wheels off (for ease & the filming) but am already nervous about the bleed process. Coincidentally, taking the actuator out isn't that difficult. The most difficult part when swapping for me has been getting the brake-lines completely flush against the actuator (i.e. reattachment of steel brake-lines). seeing the screw-in from odd angles made it more difficult than necessary along with treating the brake lines with care.
  12. priuslyfe
    priuslyfe Member
    331
    70
    This good ol' boy didn't even use any bleeder-app (techstream or autel)....he bled it like a normal car (manually just looked for no air bubbles?) your thoughts?
  13. ChapmanF
    18,939
    There'll always be some good ol' boy on youtube or PriusChat to tell you nothing matters and just treat it like a normal car.
    This actuator has eleven electrically-operated valves inside, controlling some redundant hydraulic pathways, and you get air in a lot of places when you have it out and install it, and you're not getting that air out of all those places without getting the ECU to open the right valves at the right times while you bleed.
    Brian1954 likes this.
  14. Mendel Leisk
    42,237
    I’d get the whole (safely), all wheels off, makes access a lot easier. That’s what I’ve done, for a simple brake fluid replacement, wouldn’t consider alternatives. Using jack stands, and I’ve got a slab that’s no quite planar, need to shim 1/4” under the jack stand at one rear corner.
  15. Tombukt2
    13,788
    2,497
    I've bled My generation twos just like this a million times works just fine everybody says the lights won't go off in the internal valves won't bleed or fluid won't get behind etc . So far on my 09 done years ago it's still just fine and bled like a Corolla no linear valve offset requested . So uhh.
