I swapped the actuator but have not driven it yet because trying to find the best way (read: simplest) to bleed the brakes. I don't have techstream nor a laptop. However, I do have the Autel app which has a actuator-swap function for bleeding brakes. There doesn't seem to much direction online on to use it though. thoughts appreciated.
I haven't used it post actuator-swap, but I've used the same bleeding function in the Autel that you'd use for that, and it worked. Techstream actually has two bleeding routines: a shorter one for routine things like changing a caliper, and a longer one in case you worked on the underhood bits (bit of overkill for the routine jobs). The shorter one is the one my AP200 doesn't have; it seems to just have the longer one.
thanks. I've researched it to death and there seem to be several ways that people have reportedly had success. However, some say in the end they had to get techstream, so I've been dissuaded from starting. Using Autel doesn't seem as common.
If I were to swap my actuator, I would follow that by using the existing long-form bleed procedure in my Autel AP200 that I have already successfully used.
Mostly down to how quickly you can shuttle yourself around to the various bleed screws. On my gen 3, it'll send you around in some order (I forget the order, which is fine, because it prompts you) to each rear caliper, to each of the front calipers, to each of the front calipers again (there are two different hydraulic circuits serving the front calipers, both need the air out), and to the bleed screw on the stroke simulator. Then it'll empty and re-pump the accumulator half a dozen times, and finish up by learning the linear solenoid offset. Recognizing this is a gen 2 thread, I have to admit I haven't had occasion to use the AP200 for this procedure on a gen 2, so I can't say what details might be different there.
So you had to have ALL the wheels off for the Autel method? it seems that without it, using shade tree techniques, you don't need all wheels off...either fronts or rears. also how difficult was it for a first timer???? almost considering towing to a shop to bleed because although the actuator swap isn't that hard, I know that bleeding there is somewhat more of an art to it.
You don't have to have the wheels off to bleed the brakes it makes it easier to access the parts wheels off . You can be be on ramps up front and nothing in rear. I've used the ap200 a lot to bleed the brakes because it keeps me from getting a complete laptop and cabling off the shelf and making sure that it's charged. the Ap bleed menus mimics tech streams .
I can reach all four bleed screws on my gen 3 with no special effort, all four wheels on the ground. Maybe if my arms were very short it would be different. For the front, turning the steering to one side and the other makes it easy. Gen 3 has a fifth bleed screw on the stroke simulator, which (on a US car) can't be reached without removing the windshield wipers and cowl. I do that work before starting the bleed process, so I don't have to take time for it during the process while draining the battery. If I remember right, gen 2's stroke simulator is in a different place. Having not worked through this procedure on a gen 2, I'm not sure if there are more bleed screws under the hood to be found.
thanks. some of the youtubes Ive watched have at least 2 wheels off (for ease & the filming) but am already nervous about the bleed process. Coincidentally, taking the actuator out isn't that difficult. The most difficult part when swapping for me has been getting the brake-lines completely flush against the actuator (i.e. reattachment of steel brake-lines). seeing the screw-in from odd angles made it more difficult than necessary along with treating the brake lines with care.
This good ol' boy didn't even use any bleeder-app (techstream or autel)....he bled it like a normal car (manually just looked for no air bubbles?) your thoughts?
There'll always be some good ol' boy on youtube or PriusChat to tell you nothing matters and just treat it like a normal car. This actuator has eleven electrically-operated valves inside, controlling some redundant hydraulic pathways, and you get air in a lot of places when you have it out and install it, and you're not getting that air out of all those places without getting the ECU to open the right valves at the right times while you bleed.
I’d (safely),get all wheels off, makes access a lot easier. That’s what I’ve done, for a simple brake fluid replacement, wouldn’t consider alternatives. Using jack stands, and I’ve got a slab that’s no quite planar, need to shim 1/4” under the jack stands at one rear corner.
I've bled My generation twos just like this a million times works just fine everybody says the lights won't go off in the internal valves won't bleed or fluid won't get behind etc . So far on my 09 done years ago it's still just fine and bled like a Corolla no linear valve offset requested . So uhh.
thanks. the problem is I've never used an app to bleed brakes. For reference, I only bought my first smartphone a few years ago, I still rarely use the apps and just mainly use it to make calls and texts IF necessary. therefore, I'm apprehensive to use an app to bleed-brakes and mess it up midway; get flashing codes on dash (apparently this is common per youtube videos). I'd also like to keep it as simple as possible and do it myself. I have bled brakes in my Camrys that I've had prior to the Prius. Plus I don't have any friends who would know how to help me with my car and I don't want to bother them anyways (they always suggest just sending it the shop and forgetting about fixing it yourself). thanks. did you do this by yourself or did you have a helper? If you did it by yourself, how did you do it alone? thanks.
When I mentioned there's always somebody on YouTube or PriusChat who will tell you it doesn't matter that those valves are closed when you bleed, well, here on PriusChat, Tombukt2 is the person that always is. If your priorities are to keep it simple and avoid messing anything up, my suggestion would be to do the bleeding the way it's designed to be done. Getting flashing codes on the dash isn't a catastrophe. Codes are there to tell you what's going on with the car. If you have the tool to start the bleed procedure, you also have the tool to understand whatever the car may tell you is going on along the way.
