Prius in for an oil change
Discussion in 'Gen 4 Prius Main Forum' started by TinyTim, Jun 26, 2026.
  1. frodoz737
    frodoz737 Top Wrench
    4,790
    2,555
    33
    I've only been a professional wrench for +40 years with multiple licenses and I've seen and heard this all before. You asked, but the decisions are all yours. Wish you the best.
    notspam3 and BiomedO1 like this.
  2. Bill Norton
    Bill Norton Senior Member
    2,234
    748
    MONW, Ks.
    2019 Prius
    L Eco
    Again,,,, You should never 'add brake fluid'. You're just making a problem if you do. There is a Max and Min line for a reason.
    It's a translucent reservoir for a reason.
    Resist the urge to open that cap and let moisture in.
  3. Mendel Leisk
    42,237
    Most if not all of Toyota’s service recommendations are miles or months, whichever comes first.
    Concur about not adding brake fluid, it typically drops as a consequence of pad wear, and it’s pointless to “top up”. However, regarding the cap on brake fluid reserve, while a snug fit, don’t see it as being air-tight, sealed.
  4. frodoz737
    4,790
    2,555
    33
    DOT 3/4 is most definitely not a 100K mile fluid. If your brake fluid drops close to minimum in the reservoir that means you need maintenance. Either you have a leak of some kind or you pads/shoes are worn. Fluid should be flushed every 2-3 years or 30K miles at minimum...regardless what you drive.
    #24 frodoz737, Jun 28, 2026
  5. Mendel Leisk
    42,237
    Basically means pads have thinned, pistons have come further out the calipers, and brake fluid has filled the increased void behind the pistons. With new pads you need to push the pistons back into the calipers, and the fluid level in the reservoir goes back to where it was at the outset. Barring leaks.
    Bill Norton likes this.
  6. frodoz737
    4,790
    2,555
    33
    Having owned 2 Prii and an HV RAV4...as it relates...you will need to flush the fluid before the pads/rotors ever need work.
  7. Mendel Leisk
    42,237
    Yup, per Toyota Canada:
    Lovely maintenance schedule format (attached), for the last few years of 3rd gen. For 4th gen, they completely stripped it out of the paper/pdf documents, made it online-only, in a format similar to the US Warranty and Maintenance Booklet, event-by-event, so impossible to see the patterns, unless you labouriously translate it back to spreadsheet table (which is likely how it's created...).
  8. Bill Norton
    2,234
    748
    MONW, Ks.
    2019 Prius
    L Eco
    That's some OCD thinking.....
    Does any manufacturer recommend this schedule? Can you reference one?
  9. BiomedO1
    4,482
    2,357
    Left Coast
    See thread #27. That's what OEM maintenance manuals used to look like, before total cost of ownership (TCO) was weaponized in the automotive industry. OEM sought to lower their TCO, by deferring maintenance, claiming lifetime fluids; pushing out oil changes to10K miles and requiring full synthetic oils. That pushes their TCO over a 5-8 year period down; making them look more competitive.
    Some of us wants to drive a car until the wheels fall off or when the universe has other plans. We tend to do REAL maintenance, rather than just the OEM minimum - to get us past the OEM warranty period.
    You can go down to your local library and ask if they have an old OEM manual. I just took a look at my old 1997 Honda Civic OEM manual. It's stating 3yrs or 45K miles DOT3 replacement. Now all of a sudden DOT3 is lifetime?????
    #29 BiomedO1, Jul 4, 2026 at 9:31 AM
  10. Mendel Leisk
    42,237
    Toyota Canada? Per post 27.
  11. TinyTim
    TinyTim Active Member
    414
    241
    Seattle
    I suspect your Toyota manual is from the Canadian dealers network and not Japan. Never put anything past people in the car business. I think BMW has a maintenece manual that
    Medel, do you service your Prius or do you take it to the dealership for service?
