MPG Drop to 35 MPG after New Battery, EGR Overhaul, and Tires (2010 Five/Tech)
Discussion in 'Gen 3 Prius Fuel Economy' started by Naveed Shaek, Jul 4, 2026 at 1:53 PM.
  1. Naveed Shaek
    Naveed Shaek New Member
    Yesterday
    Plano
    Hi everyone,
    I’m looking for some insight into a recent MPG drop. I have a 2010 Prius Five (Technology Package) with 180,000 miles. I recently performed a major round of maintenance, but my mileage has dropped from 40 MPG down to 35 MPG.
    Maintenance performed at 170k–175k miles:
    • Hybrid Battery: Installed brand new "Chinna" cylindrical modules. Dr. Prius test shows 111.82% capacity (Excellent condition).
    • EGR System: Replaced with brand new Genuine Toyota EGR Cooler and EGR Valve.
    • Intake: Cleaned intake manifold and verified all 4 small EGR ports are clear.
    • PCV Valve: Replaced with brand new OEM.
    • MAF Sensor: Cleaned with specialized cleaner.
    • Spark Plugs: Changed at 146k miles (currently have 34k miles on them).
    • Brakes/Alignment: Verified no brake drag and had a 4-wheel alignment 6 months ago.
    Tire Change Details:
    • OLD Tires: Kumho Solus TA31 – 215/55 R17 (I was getting 40 MPG on these).
    • NEW Tires: Bridgestone Turanza QuietTrack – 225/45 R17 (Installed 5 months ago).
    The Problem:
    Even with a perfect battery and a clean EGR/Intake system, I am struggling to stay above 35–36 MPG. My dashboard shows an Average Speed of 18 MPH, indicating heavy city driving.
    I know the tire size changed from a very tall 215/55 to a wider/shorter 225/45, and I am wondering how much of this drop is "odometer math error" versus the rolling resistance of the Bridgestones.
    Has anyone else seen a 5 MPG drop after cleaning the EGR and switching to 225/45 R17 QuietTracks? Is there anything else I should check (O2 sensors, 12V battery, etc.) that could cause this after such extensive maintenance?
    Thanks for the help!
    Yotafan likes this.
  2. Yotafan
    Yotafan New Member
    Thursday
    Wisconsin
    Do you think that it could be due to an increase in AC usage and/or the throttle body adjusting itself after cleaning?
  3. Naveed Shaek
    Yesterday
    Plano
    Thanks for the reply. I just checked my 12V battery using the hidden diagnostic menu and it is sitting at 10.9V when the car is in accessory mode. I also realized I haven't done a throttle body/idle relearn since cleaning the intake manifold and EGR. I am currently running 35 PSI in the new 225/45 R17 Bridgestones.
    Could a battery as low as 10.9V and a lack of idle relearn be the main cause for a 5 MPG drop, or are these tires just too heavy for the Gen 3?
