Seeking advice on buying a Prius v
Discussion in 'Prius v Main Forum' started by Viviparous, Jun 15, 2026.
  1. TinyTim
    TinyTim Active Member
    414
    241
    Seattle
    How many miles are on the odometer?
  2. ETC(SS)
    7,482
    Better YET, how many miles on the CAR? :D
    Depending on the history for a '14 (137 months?) you might be due for some significant maintenance.
    If those records are not available I would presume that none maintenance items have been done and proceed thusly:
    Warranty and MAINTENANCE guide is HERE:
    Toyota Manuals and Warranties | Toyota Owners
    https://MAINTENANCE GUIDE.pdf
    NOTE!!!
    There are some lots and lots of dealer recommended "maintenance items" that are NOT necessary.....and perhaps some Necessary (IMO) items that are not necessarily dealer recommended.....
    Good Luck!
    #22 ETC(SS), Jun 30, 2026 at 2:08 PM
  3. Viviparous
    Viviparous New Member
    22
    Back in California
    2014 Prius v wagon
    Thanks. I did not know that. I am still reading all of the manuals that came with it. I just got back from the insurance office; it’s now fully insured.
    Okay. I just ran another OBD check using the standalone Autel AL629 reader. No stored nor hidden codes. I just got the Veepeak dongle in the mail this morning. I will use that with the Dr. Prius app. This morning, I also ordered the AP200 dongle from Amazon.
    I am going to buy Toyota 50/50 pink coolant to have in the vehicle in case of emergencies. I checked the oil, it looks honey gold in color, so it has probably been recently changed. For motor oil, maybe buy Valvoline Restore and Protect 0W20? Or use what I have already, which is Costco Kirkland 0W20?
    #23 Viviparous, Jun 30, 2026 at 5:22 PM
  4. Viviparous
    22
    Back in California
    2014 Prius v wagon
    The car has a lot of miles: 177K. According to CarFax, it had 158K in August, 2024. This same independent dealer put in a new head gasket and new head, new water pump in November 2024, and new brake pads and rotors this past February.
    An AutoCheck and NHTSA check showed no outstanding service recalls on this vehicle. But, maybe I should have a Toyota dealership look at it.
  5. ETC(SS)
    7,482
    Depending on what part of Caly you call home, one of your fellow forum members might be able to recommend a good independent shop.
    You mentioned some coverage from the dealer which might be worth 'something.'
    Best!
    Viviparous likes this.
  6. Leadfoot J. McCoalroller
    8,261
    7,763
    Pennsylvania
    2018 Prius c
    Yeah, an independent shop is always a better choice than a Toyota dealer, once the factory warranty is out.
    Some of them know the car better than the dealer and all of them charge less.
  7. Viviparous
    22
    Back in California
    2014 Prius v wagon
    We are in Southern California for now. Two of our best friends own Prius v’s, and they both use the same independent shop. In addition, HybridPit is also a service option; they are about 8 miles away from us,
    I am excited to have a car that gets decent gas mileage and can still haul stuff when needed, without hauling too much of itself. In contrast, our gas guzzling minivan weighs 6050 lbs empty, so no wonder it only gets 18-20 combined mpg.
    I should qualify what I wrote earlier about the car’s mileage. The Carfax report printed and dated 6/16/2026 says the car has 158900 miles but this nearly matches an earlier odometer reading (158679) from July, 2024 state inspection. At the dealer lot, the Prius’ odometer read 177437 on the day of the Carfax report was printed. So, somehow Carfax was off in its odometer reporting. I assume that these are miles and not kilometers.
    #27 Viviparous, Jun 30, 2026 at 6:25 PM
  8. Leadfoot J. McCoalroller
    8,261
    7,763
    Pennsylvania
    2018 Prius c
    Jackpot. Having them so close by is great news!
  9. rjparker
    10,960
    6,876
    Sounds like the carfax report has the wrong date. Carfax is far from accurate.
    Costco oil is fine.
    The dealer is unlikely to tell you much if the car drives straight and runs smooth. They really can't predict problems that don't code first.
    At this point you need to drive the car quite a bit and check the rate of oil use, if any. Watch the passenger coolant reservoir level.
    Plus get a handle on the brake booster cycling while the independent dealer / mechanic is on the hook for a one year warranty.
  10. TinyTim
    414
    241
    Seattle
    What was the purchase price for this 177K miles Prius?
  11. analoggirl
    analoggirl Member
    148
    27
    Asheville, NC
    rjparker - I hope it's ok I jump into this thread. You seem to have the answer I am seeking!
    I just posted and hoping you can weigh in.
    I have an opportunity to get a 2017, pristine condition, from the one original owner who can no longer drive. wtth 63,000 miles. It's garage kept. But really pricey $18K+
    This is the thread I just posted. I would really appreciate your thoughts -
    "I have had a 3rd gen Prius since 2011. In 2023 I spent 7K on new battery, head gasket, water pump and tires at 234K because I knew it would take me beyond 300k. Welp, Hurricane Helene had other plans.
    It's been 3 years since it got destroyed, and I've had one lousy used car after another. I miss my Prius, but don't want the a later Gen as I like the feel, space and cargo of the 3rd gen.
    I found a 2017 Prius V with 63,000. Garage kept, meticulous records and showroom condition.
    What should I expect mileage wise.?
    Am I safe from the dreaded 3 gen issues with a 2017?
    It's priced kinda high ($18,900), but it's a one owner, retired driver, who kept it pristine and no longer can drive.
    What say yee??
    [="rjparker, post: 3615315, member: 41651"]If you are locked in on a Prius v, you should only consider a 2015-17 due to
    a. Revised pistons and rings for the oil burning issue
    b. Revised structural to improve the driver's side crash test results​
    I would make sure the dealer warranty covers parts and labor for an engine-replacement if blown, a head-gasket if failed, a clogged catalytic-converter, a replacement hybrid battery or a brake-booster assembly. Each is at least $2,500 installed.
    These problems are very hard to predict during a pre-sale inspection even for a dealer.
    There is a 20 year class action suit warranty on the inverter which is a plus from a cost standpoint but very disappointing if you are stranded away from home. Most likely the 2015-17 inverters are a better bet.
    Yes the Prius v is capable of 40-42 mpg, has a very good body, transaxles are bullet proof, the ac is stronger than a hatchback, they ride better than a standard gen3 and generally they have good 12v electrical and ecus.
    Mileage will dip at high freeway speeds, or with a weak hv battery (which is not enough for warranty) or with clogged catalytic-converters.
    The 2016-17 Prius v's are rare because very few were shipped to the US after the 2016 Rav4 nimh hybrid became available in late 2015. As an alternative, I would consider a Rav4 hybrid, a Prius c nimh or ideally, a 2019 up Rav 4 with a lithium hv battery,
    The best Toyota values in this price range are conventional Corollas, Camrys and Rav4s. Any shop can work on them and almost all parts are affordable at the local auto supply. While a few hybrid parts are now available aftermarket, most like hybrid batteries, egr valves and water pumps are inferior and short lived. Oem is often the only safe parts option and many small shops with affordable labor rates won't work on hybrid issues.[/QUOTE]
  12. analoggirl
    analoggirl Member
    148
    27
    Asheville, NC
    Congratulations!
    Can I ask what you paid and the mileage? I am looking at a 2017 with 63,000 miles, but it's priced so high...
  13. ETC(SS)
    7,482
    I was getting ready to say that this is my second "V" thread in 2 days. :ROFLMAO:
    @Viviparous - did the dealer address the issue that led to the head gasket failure?
    Hint - IMHO - it wasn't a faulty head gasket!
    A head gasket is like a fuse. When they "blow" it's because they were WORKING and not because they failed.
    AGAIN......IMO the root cause was oil change periodicities being 10K instead of 5k, and the EGR and intake being fouled.
    You're going to want to check and see if those issues were corrected - ALONG with all of the normal things that you would do with elderly cars (brake fluid replacement, inverter coolant, transaxle fluid replacement, etc...etc...)
    @analoggirl : as info.
    analoggirl likes this.
  14. analoggirl
    analoggirl Member
    148
    27
    Asheville, NC
    Duly noted.
    Thanks!
  15. Viviparous
    22
    Back in California
    2014 Prius v wagon
    The original price was just under $10K. But we paid for a catalytic converter shield (Millercat), plus taxes, documentation and preparation fees (fresh oil change, full tank of gas, detailed) and we added in the extended warranty. It originally came with the 1-year, 12K mile warranty. The total cost was $13K.
    #35 Viviparous, Jul 5, 2026 at 12:46 PM
  16. Viviparous
    22
    Back in California
    2014 Prius v wagon
    We bought a high mileage one, with 177K miles on the odometer. It wasn’t our first choice. There was another 2014 in the lot with only 71K miles for $6K more and we would have bought that one. But another buyer had already put a down payment on that one —literally a few hours before we arrived. Oh well. We had been looking since January and we just wanted a decent Prius given that our other cars were failing. Also, that other Prius was made in 12/2013, but ours was made in 5/2014. So, a bit later.
    Yes, we found the same thing. Most of the 2016-2017 that we saw online were in the $10K-15K price range, but we saw one 2017 Prius v on Carmax for $20K, albeit with low mileage. Our dealer said that after the pandemic, used car prices rose dramatically and they have stayed high ever since. But, look at new car prices. Before settling on the Prius v, we thought about buying a used RAV4 hybrid, and those prices were $20K - 40K
    I should also add that many of the other Prius v’s that we saw online (Autotrader, ISeeCars, Edmunds, Carfax, TrueCar, CarMax) were out-of-state, so we could not test drive them. Furthermore, those on CarMax only come with a 90-day, 4000 mile warranty.
    #36 Viviparous, Jul 5, 2026 at 12:50 PM
  17. Viviparous
    22
    Back in California
    2014 Prius v wagon
    Yes, RJParker, I agree with you. So, far we have driven it just over 400 miles since I brought it home last Monday morning. Oil is clear level is slightly above normal, so I may drain a bit. I have been checking the passenger coolant reservoir every morning before going to work. Rides very smooth, handles sharply with tight steering and no “play” nor looseness. Brakes great, but there is the weird (brake?) sound, but otherwise it is very quiet inside in city driving. A bit noisy on the highway, but that appears to be common knowledge about these cars.
    Yes, we are already in contact with the dealer. We will bring it in, but I also want another dealer for their opinion.
  18. Viviparous
    22
    Back in California
    2014 Prius v wagon
    The dealer changed the oil prior to me driving the car home. Assuming Carfax has some accuracy, the prior oil change was in June, 2025, about eight months after the head gasket/water pump change. But there is no mileage noted, so I will ask the dealer.
    I plan on changing the oil at the even 180K miles, and every 5K miles thereafter; starting on an even number makes it easier to keep track of when to change it next. For my first oil change, I will take it to that dealer or another Toyota dealer so that the oil change gets recorded in the Carfax / Autocheck reports. And I will make sure that they do not overfill the crankcase.
    Yes, I will check on those. So far, all of the fluids “look” new and were at their appropriate levels. I opened the caps to each of them and looked inside; of course, that does not mean that they were changed. I will ask the dealer. I never thought about this, thanks.
    @analoggirl : as info.[/QUOTE]
    Air_Boss likes this.
  19. rjparker
    10,960
    6,876
    The brake booster sound is normal even if it has increased in frequency or duration. Codes are the determinator.
    Just realize dealer service advisors are paid on commission like a car salesman. They will often "recommend" services blindly and it often works for them. Services like fuel system cleaning are never needed but often recommended.
    Like all successful salesmen they are typically friendly and seemingly "honest" . A real problem is easily explained with codes or obvious symptoms.
    The Maintenance Required Light comes on briefly after each start around 4700 miles. It will stay on after 5k miles. This warning gets reset after a 5k oil change or tire rotation. It's a more reliable indicator.
    It is also very useful to study the owners manual to learn what each light means. There are a couple like the high temperature warning that should be handled immediately or at least pulled over and shutdown.
    #39 rjparker, Jul 5, 2026 at 3:33 PM
  20. Viviparous
    22
    Back in California
    2014 Prius v wagon
    Thanks for this information. There are no codes; scanned with both the “SCAN” function on a Scanguage 2 scanner and an Autel AutoLink AL629 scanner. I have ordered the Autel AP200, but in another thread, I just read that they are not as useful because they are not bidrectional.
