Gen5 Prius -- EGR cleaning required?
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by batterybro, Jul 3, 2026 at 10:04 PM.
  1. batterybro
    batterybro New Member
    sacramento, ca
    2026 Prius Plug-in
    SE
    Is EGR cleaning required periodically in the Gen5 Prius?
    Is walnut blasting required for Gen5 Priuses?
    What other lesser-known maintenance items over 150k+ (preferably 250k+) miles of usage appear on Gen5 Priuses?
    52,755
    shouldn't be, it wasn't on gen 4. it was really just a poor design/engineering choice that toyota finally corrected
  3. Mendel Leisk
    42,241
    Gen 3 EGR was poor and evidently untested, more's the shame. Gen 3 owners ended up being the testers, and Gen 4 revisions were the outcome.
    Wouldn't hurt to pull the throttle body though, see what's lurking beneath. If it looks like a black/shiny mirror (oil pool, courtesy of PCV circuit), further investigation might be in order, and an oil catch can might be useful.
  4. Hammersmith
    Hammersmith Senior Member
    2,441
    2,502
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    - No. EGR problems were fixed over a decade ago.
    - No. Toyota uses port AND direct fuel injection. The port injection keeps the intake valves clean.
    - With a Prius Plug-in, you want to have your A/C(technically the heat pump) checked more often. The A/C system in the PHEV also keeps the HV battery cool. With all the extra refrigerant lines and seals, it increases the risk of leaks. And it's critical to the long term health of the HV battery to keep it cool. The system will give a hybrid warning light if things get too bad, but an A/C check at 8y/80k is recommended in the official maintenance schedule. Honestly, there just isn't enough data yet to be certain there's any problem(not enough gen5 PHEVs have hit 125k+ to see any trends developing), but it's something to keep an eye on if you own one.
    I'll also say that I'm a big supporter of 6m/5k oil changes no matter how little the ICE gets used in a PHEV. That opinion comes from long-time Toyota techs that are much, much smarter and more experienced than me.
    My gen5 maintenance schedule:
    6m/5k oil change
    4y brake fluid(if moisture hasn't exceeded 2.5% yet)
    5y/50k both coolants (you can go beyond 50k on the original coolant, but stick to 5y and then strictly 5y/50k after that)
    6y/60k transaxle fluid (doubt it will hurt to go longer, but the new TE fluid is still really new, so not much data yet)
    8y/80k A/C service(PHEV only) (I might consider dropping that down a bit to 7y/70k or less just to be safe)
    change air filters as needed(depends on local conditions)
    The brake fluid and transaxle fluid can likely go beyond those numbers, but I feel it's nice to space them out. By having one major fluid change per year, it gets you or a tech underneath the car every 12 months to keep an eye on things(suspension components, rust, fluid leaks, etc.). If you bundle all the maintenance together, it might be a few years between getting underneath for a major inspection, and that gives a lot of time for little problems to become big problems. But that's just my opinion on things.
    The known things that can kill a gen5 powertrain as of now are:
    - stuck piston rings from sludge (6m/5k oil changes and using a cleaning oil like Valvoline Restore & Protect if it comes in your viscosity; currently yes for 2023-25(0W16) and no for 2026 and up(0W8))
    - acidic coolant eating head gasket coating, internal seals, and inverter internals (5y/50k coolant changes to prevent it from getting too acidic)
    - overheating the HV batt (maintain A/C system in PHEV and regularly check HV batt filter in HEV)
    #4 Hammersmith, Jul 4, 2026 at 5:54 PM
  5. VelvetFoot
    VelvetFoot Senior Member
    1,404
    543
    New York State
    2026 Prius
    Possible to do coolant/brake/trans(?) fluid changeouts based on test results?
    What do you think about the dealer doing the maintenance?
    I'm having them do 5k oil changes. Also 5k tire rotations (while in factory included maintenance.)
    I'm coming up on 15k miles on the car, a '26 HEV.
    At this point in my life, I don't think I'll be doing it myself.
  6. ColoradoBoo
    ColoradoBoo Senior Member
    1,331
    952
    Monument, Colorado USA
    My maintenance schedule is similar to Hammer but I don't get the A/C looked at unless there's a problem. (But I don't have any Prime vehicles.)
    Don't forget about the hybrid battery cooler fan(s). There's an access door you remove and then can replace or clean out the little cloth filter. Also, shine a light in there and look at the fan to ensure it's not caked up with dust or stuff. (We have dogs so I worry about dog hair getting in there.)
