First fill-up, first impressions after 6 days of ownership.
Discussion in 'Prius v Fuel Economy' started by Viviparous, Jul 5, 2026 at 2:05 PM.
  1. Viviparous
    Viviparous New Member
    24
    Back in California
    2014 Prius v wagon
    We took home our “new-to-us” 2014 Prius v Five last Monday morning. Since then I have put on 405 miles (estimated 70% street, 30% highway miles) before the first fill-up with the gas gauge reading 3 bars remaining and 79 miles of driving range remaining. The average (AVG) indicator read 48.1 MPG. I put in 8.512 gallons; that works out to 47.6 MPG.
    (Note: I debated whether to drive the Prius until the gas gauge read one bar, but I did not want to run out of gas and I wanted to take advantage of the cheap Costco gas on my way to work this morning.)
    Overall, I am generally happy with the Prius v. It handles well, stops on a “dime,” rides smooth, and is fairly quite. I love that I am getting great gas mileage per gallon; it is a welcome change from the poor gas mileage of our other cars. I like the Prius’s informative instrument panel, but I wish there were readouts of engine coolant temperature, inverter coolant temperature, voltage, etc. I bought a small OBD port reader (ScanGauge II) to put on the dash to display this information.
    #1 Viviparous, Jul 5, 2026 at 2:05 PM
    ColoradoBoo, Air_Boss and bisco like this.
  2. Mendel Leisk
    42,247
    Had one of those (on our ‘10) for several years, no problems. Then, starting getting “CHECK HYBRID SYSTEM” warning, brake and anti-slip lights, and “odd” brake feel, extra pressure on brake pedal needed, almost felt like no brakes at first.
    anyway, long story short: dealership mechanic diagnosing these issues noted the ScanGauge, and that his Techstream connection (on the same OBD port) was dropping when he tapped it, proposed disconnecting the ScanGauge for a while, to see if the issues would cease. I did that, no further issues.
    Seems the constant weight of the ScanGauge obd connector was messing something up, causing communication errors. Lots use SG with no such ill effects, but just something to keep in mind.
    Viviparous and Air_Boss like this.
  3. Air_Boss
    Air_Boss Senior Member
    4,244
    1,195
    New Yawk
    Experienced the same with a "P12 Car Head Up Display OBD2 Digital OBD Gauge HUD Auto Diagnostic Tools Meter".
    Nice tool, but one time, mid-trip, the dash lit up like a holiday display, ABS and REGEN went flat, etc., while the P12 numbers remained in the expected ranges.
    Pulled the OBD2 connector, pulled over, shut down and restarted the Prius v Five and everything was back to normal.
    Seems as if feedback from intermittent comms make the car start to go wonky.
    Viviparous and Mendel Leisk like this.
  4. Viviparous
    24
    Back in California
    2014 Prius v wagon
    UPDATE: I was curious why the calculated MPG (47.6) did not better match the Prius’ AVG MPG (48.1) as shown on the dash cluster. Then I remembered that before driving the Pirus off the lot, the salesman asked me if I wanted one last test drive with him. So, I drove it on some city streets for maybe 3-4 miles. And then, at the gas station this past Sunday, when I filled up the tank, I topped it offer at it the pump stopped automaticallly at (I think) 8.46 gallons. So, if these are taken into account, 408 miles / 8.46 gallons = 48.2 MPG.
    P.S. I know that topping off is not recommended. I just did it this once, and will not again on this car.
    Since filling up, the AVG MPG readout has been between 48.0 - 48.6. I am still amazed. I would have had to fill up our minivan at least twice during this same week, and it has a 20-gallon gas tank.
  5. Mendel Leisk
    42,247
    Toyota likes to BS. In my experience (with our 2010, it averages about 7%.
