Easier to swap in a used engine or do a head gasket replacement?
Discussion in 'Gen 3 Prius Technical Discussion' started by weapon, Jul 9, 2026 at 9:37 AM.
  1. weapon
    weapon Junior Member
    47
    OR
    Looks so simple to swap in a used engine vs the head gasket.
    Am I correct?
    What are some of the pitfalls of a swap?
  2. JC91006
    JC91006 Senior Member
    16,933
    8,643
    a pitfall would be the used engine you put in will have more problems than the one you're replacing. But since you have a 2010, considered the worst engine year for 3rd generation, it probably would benefit you more than the potential pitfall to swap engine
    #2 JC91006, Jul 9, 2026 at 10:44 AM
    Mendel Leisk and weapon like this.
  3. weapon
    47
    OR
    Yes that is a major concern I do have right off the bat. I have been watching the head gasket replacement videos and it seems really labor intensive and lots of places for user errors if not careful.
    When I did the manifold/egr swap, I was looking at the engine and it seemed like a relatively simple engine swap. It just seems to be a very well enclosed process. I would for sure try to get a low milage 2015 replacement.
  4. ASRDogman
    ASRDogman Senior Member
    8,035
    4,073
    How many miles do you have on the engine? Is it burning oil?
    Replacing the head gasket is less expensive. As long as the head is not warped.
    Did the engine overheat? If you are replacing it because it JUST started leaking, you're likely okay.
    Replacing the engine is not really a "hard" job, just a lot of steps. If you go slow and take your time,
    you'll be able to do it if you have the ability.
    But putting a used engine in, is risky. Do you KNOW it's from a 2015? Do you KNOW if the mileage is
    actually the REAL miles. How well do you trust the people you'll getting the engine from?
    It would be best to get a remanufactured engine.
  5. weapon
    47
    OR
    It is the one with the pink goop issue from my other post. Almost 200k. Been burning oil for the last 5 years. 1& 3 spark plugs were coated in oil when removed during the cleaning. Got it all back together and the pink goop has returned. I also noticed that the torque power is lower on this one vs my 2010 with only 160. Every day I drive it, she just keeps hinting to me it has head gasket issue. Not fully blown but small leak.
    After more research, with the oil burn and the head gasket, I might be better to just find a 2015 engine and do a swap instead of putting a bandaid over the probably ring issue.
  6. Mendel Leisk
    42,251
    Maybe ask @Tideland Prius to merge threads?
  7. weapon
    47
    OR
    At this point, there are tons of these on/off the road. There is a makeshift cottage industry near my area where the local Russians and Serbians have full lots of crashed gen 3. A lot of them still with lower mileage running engines (60-100k). So finding a good donor is not really a problem. 2015 specific might make the search a bit harder. Since the car is still running, not overheating and driving fine, I can keep going for a while i search.
    A remanufactured engine is $4k+. I can get a whole new used prius for near that price and not have to do any work.
    Different question entirely than that thread. Not trying to diagnose an issue but to get opinions on an engine swap vs head gasket.
    #7 weapon, Jul 9, 2026 at 12:42 PM
