hazard lights not turning on?
Discussion in 'Gen 3 Prius Main Forum' started by Dan Bruno, Jul 10, 2026 at 6:53 PM.
  1. Dan Bruno
    Dan Bruno New Member
    Yesterday
    ma
    Hey fellow Prius drivers. I recently bought a gen 3 Prius. When I was checking it out I forgot to check the hazard lights. they don't turn on. I believe the fuse and relay are the same for the blinkers which work fine. I removed the center panel andThe switch looks ok. I even pull out the top of the dashboard and checked the connector there. It seems fine as well. Any ideas would be appreciated!
    52,768
    the only thing I can think of is to trace the 12v circuit with a meter
  3. ChapmanF
    18,950
