Sealing off cylinders without screwing spark plugs back in?
Discussion in 'Gen 2 Prius Technical Discussion' started by pasadena_commut, Jul 11, 2026.
  1. pasadena_commut
    pasadena_commut Senior Member
    3,033
    942
    Southern California
    At some point I need to do a piston soak, and I want to check the level of the solvent in each cylinder periodically using some sort of dipstick. Normally the cylinder is (mostly) sealed off by screwing in the spark plugs a few turns, but I'm looking for a sealing method that doesn't require taking them in and out frequently.
    Teflon is not affected by the organic chemicals, like those in a product like Berryman's B12 Chemtool.
    So the simplest method would be to get some teflon disks the same size as the upper part of the coil pack, and just set those down were the coil packs normally go. Maybe with a little arm so that the pack retaining bolt can hold it down. This would be cheap and easy. Unfortunately it might be a problem because the edge of the valve cover gasket would be constantly exposed to fumes from the solvent for a period which could be a couple of days. The vapor pressure for the Acetone component could be as high as 500 Torr on a hot day (if the compartment is fully sealed), and that might chew up the valve cover gasket, eventually leading to oil dripping down onto the plugs. (The edge of the head gasket is subjected to the same chemical environment, but whatever it is made of is pretty resistant to gasoline. Plus I have never heard of a head gasket failure following a piston soak in a Prius.) The valve cover gasket is exposed to the solvent briefly when it is poured in or blown out, but the stuff is so volatile the contact is likely only for a minute or so.
    Jamming a rag tightly into the top of the hole would be easy, but potentially have the same issue with fumes damaging the valve cover gasket, plus it might introduce other issues like not sealing as well or stray lint or threads getting into the cylinder.
    To avoid that potential valve cover gasket issue, it would have to seal where the spark plug normally is placed. For the sake of argument let's say the diameter of the washers on the plug is 1/2". My first thought was to obtain a teflon ball a bit bigger than that, drill it half way in, tap it, and put some threaded rod in the hole. Picture an olive on the end of a big toothpick. It would be possible to feel when the ball is "in the hole" and just lean the rod over onto the edge of the hole in the valve cover. The problem here is that the threads for the spark plug probably come right up to the surface of the metal (anybody know for sure ?), so there is some chance the ball might bend the lead in thread, which would really suck if the plug could not then be threaded back in!
    A more complicated plug would use a bit of teflon cylinder on the same sort of metal threaded rod. There would be no way to tell when it was centered on the hole though, at least by feel. Anybody know the inner diameter of the cylindrical area around the top of the plug? If the teflon cylinder is a bit smaller than that, and it has an upper piece of some sort that centers it on the upper hole, the cylinder should sit square over the spark plug hole sealing it, and stopping fumes from reaching the valve cover gasket - which would also be well ventilated to the atmosphere if any did get by the plug. I don't know how smooth the area is past where the plug sits, possibly the plug could not sit flush. It would have to be thoroughly blown clean to keep any bits of dirt from preventing a good seal.
    Any other ideas?
  2. Tombukt2
    13,827
    2,510
    A bolt stuck in a tube of plastic pipe. 4 of .
  3. Leadfoot J. McCoalroller
    8,278
    7,783
    Pennsylvania
    2018 Prius c
    Fine, I'll bite.
    All of that sounds a lot harder than just putting the plugs back in.
    What's so bad about putting plugs where they belong?
  4. pasadena_commut
    3,033
    942
    Southern California
    Nothing, once, or even twice. However, I wanted to get some numbers on how much solvent remains in each cylinder over time, probably every 4 hours or so for two days. That's a lot of de- and re- installations.
  5. pasadena_commut
    3,033
    942
    Southern California
    Head down, threaded shank up? Could work if I can find some bolts of the right size with perfectly flat heads and no raised letters.
    It does make me wonder if the washers on the OEM spark plugs are steel or aluminum?
  6. Leadfoot J. McCoalroller
    8,278
    7,783
    Pennsylvania
    2018 Prius c
    I'd be nervous about using anything other than a plug. They're already highly engineered to seal properly and not fall into the combustion chamber, among other things.
    So I say if you want the data, do the work.
  7. Hayslayer
    Hayslayer Active Member
    529
    320
    I guess you really want to make this tough, but an easy way is just to use some wooden dowel rod.
    The Gen 2 spark plug uses a 14mm thread. which is just slightly smaller than 9/16". You could easily get 9/16" or 5"8" dowel rod, taper the end slightly and just drop it into the hole and give it a turn or two by hand to make it seal. Heck, a 3' piece is probably 5 bucks at lowes or home depot.
  8. Tombukt2
    13,827
    2,510
    They make plastic rods already ready to do this
  9. pasadena_commut
    3,033
    942
    Southern California
    Many, probably most, plastics are going to be damaged from Berryman B12 Chemtool contact or fumes. Assuming as is claimed that it is mostly acetone. Relatively inert plastics included. There is a reason it comes in metal cans. Teflon isn't affected by acetone, but dropping some random plastic rod on top of the spark plug hole and then bathing it in acetone fumes for hours seems like a great way to melt goop down that hole, onto the threads, and possibly all the way onto the piston.
    If the plastic rods cited above are rated for this sort of chemical please provide a link.
  10. Tombukt2
    13,827
    2,510
    Try schedule 80 plastics I don't think the berryman is going to make that really soft . I'll try it in a few I've some rounds of sch 80 grey . I won't thread them for the spark plug holes I'll just apply the chem tool to the schedule 80 and see if it raises grain of plastic if you will . Initially I was meaning pieces of rubber hose with threaded stud correctly sized in the tubing . Hand tight. You know the clear poly tubing that can withstand almost all chemicals and nonsense. But it's only holding on to the metal shaft for you to be able to twist
  11. rjparker
    11,040
    6,920
    While B12 might help unstick rings and solve something early on, by the time oil consumption is obvious the low tension rings are worn and need replacement to solve oil consumption even temporarily. If you went that far, change the pistons at the same time for good long term results. No need to risk bearings and cylinder walls with a solvent.
  12. pasadena_commut
    3,033
    942
    Southern California
    Oil consumption at the last change was 1.8 qt/5000 miles. That isn't dreadful, but the year before it was 1 qt/5000 miles. Plus it got worse despite the last several oil changes using Valvoline Restore and Protect. My thinking is that it is worth giving the soak a shot now because in terms of oil usage this is still early days, but the direction things are going isn't good, and the VRP by itself does not appear to be doing the trick. (The car only sees 5k miles a year, most of it is in short trips, this may not be ideal for the way that product works to remove carbon.) I agree that the ideal fix would be to replace the pistons and rings and if the cylinder walls aren't damaged that should resolve the issue. Unfortunately it would be a ton of work and/or money which is hard to justify at the current level of oil consumption.
  13. rjparker
    11,040
    6,920
    Valvoline R&P and B12 are probably the best for keeping a clean engine but curing oil consumption is a stretch. A guy on youtube named DIY Dave did a year's long test of products on his low tension Corolla with some reduction but no real cure. B12 and the super Valvoline Restore (no longer available) cleaned things very well. He would try each secret potion and run many 1000's on each. When he finally gave up and tore the engine down he found the oil return passages and the piston ring groves clear and functional. Swapped in new pistons and rings and his oil consumption went away. Which is the same thing Toyota did for free for thousands under the gen3 oil consumption tsb.
    Oil consumption can take out the catalytic converter and will absolutely turn the egr cooler into a gummy mess.
    At this point, most would wait for a head gasket fail and change the engine or junk the car.
    #13 rjparker, Jul 13, 2026
  14. Mendel Leisk
    42,298
    Assuming you’re replacing rings with the revised ones, it’s mandatory to replace pistons as well; the pistons have had a revision too, and the new rings will not fit in the old pistons.
  15. rjparker
    11,040
    6,920
    You can buy replacement rings for the original design pistons which is relatively low cost for a diy'er who is not paying labor. Rockauto has a set for $55.
    Revised pistons and rings from Toyota are $500 from an online Toyota dealer.
    Either way you have the head gasket set and optionally machine shop head work adding another $500-$1000.
    With the advanced age of these cars, a replacement engine (low mile JDM with accessories $1000) might be more cost effective than revised pistons and rings. Especially if you are paying for qualified labor.
  16. pasadena_commut
    3,033
    942
    Southern California
    Yeah, seen many of those videos. He did not start until the car was burning a stupid amount of oil, like a quart every 300 miles. That is I suspect often a "horse is already out of the barn" situation as far as ring wear goes.
    Conversely, there are a lot of reports of people who pretty much fixed oil consumption issues on other cars. Kaptainkid1 who used to post in this forum had a thread
    200k 2009 Prius with oil burning at 1qt for 1000 miles highway and less burning in stop and go. | PriusChat
    and he started when the car was burning about 1 qt per 1000 miles. The oil consumption would return, but not quickly. He said in a private message:
    I used berryman's B12 solvent. I piston soak the Prius every other oil change for 2 years and basically the car stop burning oil. Due to Piston soak schedule. I think it would started to burn oil maybe after 3 or 4 oil changes without Piston soaking. So my guess after 10k-15k of regular oil changes.
    I'm hoping that the piston soak knocks back the oil burning to something less than 1qt/5000 miles, and that continued use of VRP will hold it there. Even if it doesn't, at 5k miles per year, for us that would be a piston soak every 2 to 3 years, which isn't horrible as maintenance tasks go.
  17. pasadena_commut
    3,033
    942
    Southern California
    Not sure what the technical term is, but is the area in the head where the plug screws in generally flat not just where the plug washers sit, but nearly all the way to the wall?
    If so...
    Maybe a valve from a (big) ICE engine? In general, the combustion chamber part is round, flat, and smooth, and there is a long metal stem extending upward. They tend to be relatively heavy since they are made of steel. Maybe heavy enough to keep the pressure from the evaporating solvent from pushing it off the spark plug hole? If the stem came up all the way out of the head one could put a thimble shaped weight on the end to hold the business end flat despite the gas pressure. Steel won't be damaged by the solvent in the cylinder.
    Not sure how I would go about finding one with the right dimensions. I only see these spec'd for specific vehicles, not by diameter of wide part vs. length of stem.
