Insane tire wear at 30k miles. ‘23 Prime SE
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Zyrian, Jul 10, 2026 at 1:05 PM.
  1. Zyrian
    Zyrian Member
    44
    31
    ATL
    2023 Prius Prime
    SE
    Was driving from Atlanta to the Gulf and had a fun Rapids Unplanned Depressurization of the front passenger tire. Good thing I’m weird and made myself a spare tire kit.
    Tire looked awful and I thought it was because of riding couple hundred yards on the interstate stopping from 70. Of course size is impossible to find, especially in rural FL. But got a shop that could get it, and when they lifted the car they showed me the rest of the tire.
    Long story short - alignment issues destroyed the tires, all 4 needed to be replaced. I opted for 215/55 as an experiment - diameter is the same.
    Fun pics attached. 30k on the odometer, just hit 3 years, was at the dealer for service 4 months back - didn’t hear a peep.
    What do you guys think about 215/55?
    52,773
    didn't anyone notice at the previous services?
    BiomedO1 likes this.
  3. BiomedO1
    4,519
    2,378
    Left Coast
    They should've caught that on your last tire rotation @ 25K. Looks like it was toe-out really badly. Did you wack a curb really hard or gone over some major pot holes?
    I would stop using that dealership; since that's on the basic safety check list. Any blind mechanic should've found that. Makes me wonder what else they're checking off and not doing???? Did the dealership tell you that you needed an alignment and tires????
    #3 BiomedO1, Jul 10, 2026 at 8:18 PM
    mva likes this.
  4. Zyrian
    Zyrian Member
    44
    31
    ATL
    2023 Prius Prime
    SE
    Nope, I’m at the dealer every 6 months / 5k miles and got “all good”. Tires good, brakes good - can’t be better. Dudes didn’t check it, it seems.
    all 4 had inside edge wear, and fronts started just disintegrating (middle pic). Had 2 dozen cars in almost 30 years, never had anything like that. And I autocrossed and did road course and tail of the dragon runs. My fault for not double checking. Got fat and happy and trusted dealer.
  5. BiomedO1
    4,519
    2,378
    Left Coast
    I'd take those pictures, alignment paperwork and speak to the dealerships service manager. Their going to say that you whacked a curb, but since all 4 had inside wear - they've been rotating them and not noticing the issue.
    Why do 6 month / 5K checks if they don't recognize obvious issues?????
    Who knows; they might give you a few FREE oil changes - but I would be afraid they'd screw that up too.....
    You can tell that I do my own basic maintenance, so I don't get surprises like that. I also do fluid checks and basic walk around before a long trip.
    Hope this helps....
  6. Mendel Leisk
    42,262
    That's the thing. Best to just stay away as much as practical, DIY.
    Tande and BiomedO1 like this.
  7. frodoz737
    frodoz737 Top Wrench
    4,791
    2,559
    33
    That wear didn't happen overnight. Does no one do a basic walk-around, check their fluids, or stick their tires anymore?
  8. LRO
    LRO Member
    76
    89
    United States
    2024 Prius Prime
    XSE Premium
    Couldn't help to notice that you had a mix of tires replaced ... Bridgestone and Toyo A/S Extensa II. Which brand did it originally come with?
  9. BiomedO1
    4,519
    2,378
    Left Coast
    Inside wear is tough to find; unless you get on your hands and knees or do your own rotations. Those pictures tells a story of long term neglect and obvious alignment issues. I don't see how that was missed on the dealerships basic safety inspections. There should be notifications in the dealerships paperwork to cover their asset from liability law suits.
  10. Zyrian
    Zyrian Member
    44
    31
    ATL
    2023 Prius Prime
    SE
    Eagle eye! I got the car used with 6K miles on it, didn't check if the tires were replaced, but you are right, it's a tire salad. Looks like 3 were Toyos, thus original, were in ok shape except nasty feathering on the front (where I could peel the layer by hand). Guessing they didn't rotate my tires last time and I ended up putting 10K on the same set with bad alignment.
  11. BiomedO1
    4,519
    2,378
    Left Coast
    You were down below the cords on that Bridgestone. That isn't just 10K miles of wear; that's a combination of under-inflation and misalignment over a lot of miles - more than 10K.
  12. Agent337
    Agent337 Member
    51
    27
    Orange County, California
    2023 Prius Prime
    SE
    2023 Prius Prime SE on Bridgestone Ecopa tires with 22,540 miles on them. Recently have experienced some rough tread wear as well.
    Miles 13,156 to 17,022, tires went from 6/32 to 5/32 tread depth. Nothing crazy, but from 17,022 to 22,333, tread depth plummeted from 5/32 to 1/32 (according to Toyota). Went to a local tire shop and they said 2/32 - 3/32. All tires have inner sidewall wear, smooth with some bumps where the tread used to be. Ordered tires since 195/60R17's aren't readily available, then will do a full alignment.
    With so much wear in 5K miles, what do you guys think the main culprit is? Toe? Camber?
  13. Quovadis007
    Quovadis007 Junior Member
    25
    COVENTRY
    2024 Prius Prime
    Business Ed. Plus
    Your tire pressure was simply way too low. After all, garages like to sell tires.
    Personally, I have always set my tire pressure to the maximum recommendation for 35 years.
    For the factory-fitted Yokohama BluEarth-GT AE51 195/50 R19 88H RPB, Toyota advice, 2.6 bar at the front and 2.4 bar at the rear, for the Prius Phev exclusive 2024. (Highway)
    Do measure this in the morning and not in the sun. They wear perfectly evenly after 26,000 km. 2.7 bar at the front and 2.5 bar at the rear won't do any harm either.
    If you drive on the highway on a hot day, the pressure temporarily rises quickly to 3.1 bar and 2.8.
  14. BiomedO1
    4,519
    2,378
    Left Coast
    Improper inflation and misalignment (toe). Any shop will provide a before and after alignment reading; unless they are working with really old equipment.
    I keep all my tires at 38 psi, so I don't have to check them when I rotate them. Even wear all the way across. I only got around 30K on the OEM's and replaced them with 65K mile tires.
