Considering A Newer Prius
Discussion in 'Gen 3 Prius Main Forum' started by mjgill1, Jul 13, 2026 at 5:23 PM.
  1. mjgill1
    mjgill1 Junior Member
    Eastern Iowa
    I've had my 2010 since 2012 and 53,000 miles. It now has 242,000. Not so long ago I replaced the intake manifold, EGR valve and cleaned out the EGR cooler to be like new. Things were fine for a while. Well, it's doing the shimmy and rattle at start up again and occasionally shuttering under light acceleration. Hope it's not the tranny. I'll probably pull the EGR off and take a gander at it, but it has less than 10,000 miles on it, who knows.
    Anyways, I am considering looking at something in the 2020 range. Is there anyone who knows which of the newer generations are the least problematic? Or, maybe better said, as reliable and long lasting as my 2010? Also, I need the same amount of space with the rear seats down which seems to eliminate the newest generations from consideration.
    Any help or direction would be appreciated.
    Thanks,
    #1 mjgill1, Jul 13, 2026 at 5:23 PM
  2. ASRDogman
    ASRDogman Senior Member
    8,045
    4,077
    Are you loosing engine coolant? Kinda sounds like the head gasket has failed.
    It's extremely unlikely the transmission is bad.
    The Gen 4 has less issues.... So I've heard anyways. Depends on who you chat/talk with.
    And what you believe.
  3. Tombukt2
    13,809
    2,504
    The latest thing is using the detuned Camry engine an MA or AM . Timing chain engine from Camry detuned for Prius duty . Once they regularly start pegging over 200,000 I'll be looking at until not so much . The power plant has to prove itself for me to buy it and then the interior and chassis are welp cheap not to. Keep type stuff.
  4. rjparker
    11,006
    6,896
    What are you talking about when you say "engine from Camry detuned for Prius duty"?
    The latest dual injection 2.5L used in Camry and Rav4 hybrids? Into a Prius?
  5. mjgill1
    Eastern Iowa
    Coolant is still in the reservoir. I guess the 2010 was notorious for head gaskets. I've never replaced it.
  6. ASRDogman
    8,045
    4,077
    It doesn't take much. Using a bore scope in cylinders 1 and 2 with pressure on the
    cooling system might show coolant leaking into the cylinders.
    387,000 plus miles on my 2010. I replaced the head gasket at 301,000 miles....
    mjgill1 and Tombukt2 like this.
  7. ColoradoBoo
    ColoradoBoo Senior Member
    1,338
    961
    Monument, Colorado USA
    We have two Gen 4's, 2017 and 2021 and both have been boring for this DIYer! (I have to rely on our 2008's to get to do any of the fun stuff.)
    Seriously, though, don't limit your search to the Prius....the Corolla and Camry Hybrids are, also, excellent! And even a late-model Avalon Hybrid. (My co-worker has one....rides as smooth as a Lexus!)
  8. bisco
    52,779
  9. mjgill1
    Eastern Iowa
    I appreciate the sentiment, but it has to be a Prius as it is a company vehicle and the amount of storage in the rear area with the seats down was not reduced (from what I have been told) the body style of 2021 and later. It's remarkable how much stuff I carry in that car!
  10. mjgill1
    Eastern Iowa
    So you're saying that the start up rattle and shake is potentially the head gasket? I thought it had to do with the EGR? Was it a PITA to replace?
  11. ASRDogman
    8,045
    4,077
    It's a common issue. Without doing a coolant system pressure test and a bore scope
    in each cylinder, where you can see coolant leaking, you won't know for certain.
    Check the coolant level when the engine is cold, like sitting overnight.
    Then try to park it in the same place over night again. Or when you get fuel.
    If you see that the coolant is slightly lower each time, or close, then likely, it's a failed head gasket.
    It's no harder than on a non hybrid car. It will depend on what tools you have and your skill level.
    The trickiest part is getting the timing chain cover back on. It's not hard, you can force it. You just kinda
    "place" it on. Then get all the bolts in and tightened. It's easy to get the timing chain on because there
    are 3 colored links to set the chain in place. Ease in the timing chain tensioner in place, rotate the engine
    backward a little bit, and slowly to release it. Rotate the engine close wise two complete turn and check the
    timing marks.
  12. mjgill1
    Eastern Iowa
    I have the skills. I used to do a lot with cars back in the day. It's certainly been a minute, but can look up torque patterns, specs and what have you. I'll mark the coolant and see it she's drinking it. If so, I could save myself a lot of money by just doing the gasket. Maybe get another 50K out of it. I'm still on the original hybrid battery.
    A service manager at our local dealer said that 2020 and below should have the same amount of space in the rear with the seats down. That's really the kicker for me, at least for the next five years or so. That, and the newer ones have a lot of nice features like blue tooth calling, less road noise, etc. etc. He also said that the 2020 should have the least amount of problems? IDK. Mine is an old rattle trap, but does the job.
  13. ASRDogman
    8,045
    4,077
    Then you can certainly do the head gasket!
    Do it BEFORE it gets bad, and possibly warp the head.
    But, always check it with a straight edge.
    And replace the valve guide seals.
    You will need a smaller valve spring compressor. Mine was too big, but I had a washer I placed over
    the retainer washer, but it slipped and one retainer went shooting off! I eventually found it!
    Lay the head on a level bench and spray some WD40(or other light oil) on the valve so it covers the
    whole seat. Wait 15 minutes or so then carefully lift the head and check to make sure all the valves
    are seating correctly and there are no leaks. If any are leaking, seat them all in.
    I have 86,000 plus miles on my replacement head gasket.
    Get the FULL head gasket kit from Toyota, and head bolts. If you're a veteran, they usually give you a
    10% discount.
    mjgill1 likes this.
  14. mjgill1
    Eastern Iowa
    When you say seat them in, do you mean pay for a valve grind from a machine shop?
  15. ASRDogman
    8,045
    4,077
    No, take the valve out, put some valve grinding compound on the valve and seat.
    Then either use a suction cut on the valve and spin it back and forth with your hands and bounce it on the seat.
    Do that several times, take the valve out, use carb cleaner or brake cleaner, and clean off the valve and the seat
    and see if you have a nice even pattern.
    Unless they are really bad, then you may need a machine shop. But the car would be running bad if they
    were leaking a lot.
    Are you burning oil? Depending how much it's burning, and how much you drive, you might want to
    consider a short block.
  16. rjparker
    11,006
    6,896
    The gen3 egr only causes startup stumbles and continuing low rpm roughness if it is stuck open. A revised egr valve and ecm software is available. A simple block flow test can rule that out.
    A gen3 head gasket leak begins by showing symptoms very occasionally, often weeks between severe rattles that quickly clear for the rest of the day.
    He is correct about that since a complete reengineering of the engine was done for the gen4s. It has no unusual amount of head gasket or oil burning issues.
    Most mechanics, dealers and pro shops recommend a head inspection, rebuild and valve seals by a machine shop when repairing a gen3 head gasket.
    Oil burning is common on gen3s and is an important factor if dealing with a hg problem. Toyota acknowledged that pistons and rings through a mid 2014 production change were poorly designed and replaced thousands with revised parts under warranty early on. Many with high miles and a hg problem choose a replacement engine if faced with a hg and oil burning. Or trade the car.
    Videos
    Shudder video when a hg is advanced.
    “Hey Walt… they want to wait and see if it gets worse…”
    Car Care Nut HG Borescope at 7:40
    Start with no cost egr block flow test
    #16 rjparker, Jul 15, 2026 at 12:07 PM
    mjgill1 likes this.
