Is there a spec sheet on what the maximum wattage inverter I could run off of my Gen 4 prius? So far I've run my TSW 1K inverter with an angle grinder, jig saw, belt sander, and a 100 watt per channel stereo amplifier. The power tools were all old Craftsman brand that maxed out around 450 Watts, even under load. Thank you.
Does a Gen 4 Prius have V2L from the traction battery? Or are you using the 12v lead acid battery to power the inverter? T1 Terry
.....just a swag but they probably fuse the DC-DC converter at 100a. I wouldn't go much above a 1000w inverter, which has been done many times here in the forum. MAYBE 1500w if you carry a spare fuse..... Good Luck!
I meant to add a search link like this last night, since so many threads here already talk about it: https://priuschat.com/search/1010014444/?q=12v+inverter+wattage&t=post&o=relevance Last night it seemed like Search hadn't recovered from the recent outage yet, but now it looks like it has.
