The brake, ABS, VSP lights on the dashboard of my 2007 Prius will not go out. M
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Alill, Jul 16, 2026 at 5:23 AM.
  1. Alill
    Alill New Member
    Wednesday
    Chicago suburb
    My 2007 Prius would not start even though I installed a new 12v battery. My mechanic installed an inverter pump which resulted in the engine starting. However, the car will only start if the fob is inserted and the brake, ABS, VSP, lights, will not go out. Do I need to replace a sensor?
    52,789
    you need a mechanic with a prius aware scanner to read the trouble codes which tell you where the faults may lie.
    did anyone test the new battery to make sure it is fully charged? did you install a quality fresh fob battery?
    Brian1954 likes this.
  3. ChapmanF
    18,961
    The mechanic might have (on purpose or inadvertently) turned off the proximity key function with the KEY button under the dash.
    You can find out what those lights are telling you without having to shop for a scan tool first:
    Blink (a/k/a Flash) Codes – How to. | PriusChat
  4. Alill
    Alill New Member
    Wednesday
    Chicago suburb
    The mechanic charged the new 12v battery. I had a new battery installed in the fob.
