Coolant temperature sensor blues
Discussion in 'Gen 3 Prius Main Forum' started by Wrecit, Jul 18, 2026 at 7:47 PM.
  1. Wrecit
    Wrecit Active Member
    182
    114
    Pittsburgh
    2001 Prius
    I
    I hope there is a special level of hell dedicated to the engineers that designed the engine bay on the 2010 Prius.
    Coolant temperature sensor went on my wife’s DoorDash car. A $28 part and should be a 20 minute job.
    Have half the engine bay dismantled and still can’t get leverage on the safety lock button on the plug end to get the frakin thing to disengage so I can get a socket on it and I only have the good non slip crows foot wrenches so I can’t even slip a crows foot wrench on to turn and expose the button.
    May a million sand fleas from a leapers camel infest their crotches for eternity
    anyone got any tricks on pushing the release button when it’s at 6 o’clock and crusty from 16 years of working? Can’t find my grinder or else I would cut the “safety tabs” off my 3/4 crows foot and just break it loose to better access
    PriusCamper likes this.
  2. PriusCamper
    PriusCamper Senior Member
    13,416
    5,416
    Pacific Northwest, USA
    I'm just get used to a really cheap 2010 with similar thoughts... Every time I look into it I find more stuff that needs to be fixed. So different than Gen2 Prius that hardly has anything wrong with it.
  3. Mendel Leisk
    42,286
    Is there more than one sensor? Just browsing the Repair Manual, is it this one, in the junction with white (air-release) cap on top, at a hose juncture above the EGR components:
    For another bone-head access issue, I'd nominate the inverter coolant pump: short of some metalwork, you need to remove the effing inverter to get to it.
  4. rjparker
    11,020
    6,912
    There are two, your pic is downstream of the exhaust heat recirc system ehrs flow and sensors partial.jpeg
    This one is at the large engine to radiator hose
    #4 rjparker, Jul 19, 2026 at 11:58 AM
  5. Mendel Leisk
    42,286
    Thanks, yeah, I was thinking as much.
    #5 Mendel Leisk, Jul 19, 2026 at 12:00 PM
  6. rjparker
    11,020
    6,912
    You can buy a connector removal tool or a set that holds the clip down while you wiggle it off.
    CR94 likes this.
