2012 with 279k miles overheating
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Sharnold, Jul 18, 2026.
  1. Sharnold
    Sharnold Active Member
    409
    126
    Alabama
    I recently acquired this car cheaply and replaced the headgasket and cleaned the egr system.
    Water pump is working heat currently is not and I'm getting an overheating issue pulling the mountain with antifreeze coming out of the relief on the coolant reservoir.
    Fans- working
    Water pump- working
    Heat- not working
    Egr- spotless
    Egr valve- clean and functioning
    techstream shows everything working as should be no faults other than B1503
    Sometimes the reservoir has pressure other times it doesn't
    No leaks with the headgasket or miss fires
    Engine coolant isn't low
    Previous owner used Red devil block sealant ‍and I'm leaning towards radiator
    Opinions are welcome
    #1 Sharnold, Jul 18, 2026
  2. ChapmanF
    19,026
    B1503 code is pretty specific. Maybe look ➡here⬅.
  3. rjparker
    11,113
    6,972
    B1503 Exhaust Heat Recirclation System overheating after sealant:
    This is pointing to a) no flow through the heater (there is no valve in the heater loop), b) heater core restrictions caused by the sealer, c) clogged engine thermostat d) reduced flow from the engine water pump (typically a cracked or swollen pump impeller) or e) insufficient coolant volume resulting in the heater core being air locked (a low coolant volume side effect).
    Radiator clogging is not very common but aftermarket radiators or water pumps are not recommended.
    Its not clear how you verified the water pump flow but it can be intermittent or it can have partial flow without setting its own code.
    However your b1503 code directly points to the Exhaust Heat Recirculation System (EHRS) which has a second coolant temperature sensor downstream of that system on a small diameter hose.
    That sensor sets your code at 248f, which is over 50f hotter than normal operating temperatures. Not good.
    Monitoring both temperature sensors helps by using Toyota Techstream or a good bluetooth based app like "Car Scanner". Car Scanner is easier to read and graph. Using Techstream, you can read one of them in the Data List for "Engine and ECT", and the other one in the Data List for "Combination Meter".
    Normally exhaust flow through the EHRS system is diverted through its heat exchanger when cold and mechanically opens when hot to allow straight through flow.
    We have seen cases where the EHRS remains closed in its initial diverted state causing high downstream temperatures which then trigger the b1503 sensor.
    A few stuck EHRS cases without other factors like sealer, head gasket or water pump issues have not caused overheating on the engine block as reported by the other temperature sensor.
    Further isolation is needed. The fact your reservoir cap relieves indicates high temperature and pressure there although the reservoir loop bypasses radiator cooling.
    #3 rjparker, Jul 18, 2026
  4. BiomedO1
    4,608
    2,416
    Left Coast
    Any block sealant can and will block any narrow passages; including and not limited to the thermostat, radiator, EGHE, heater core, and coolant switch valve - if so equipped. I'd pull the bottom radiator hose to see if there's any sludge there. I believe that stuff is heat activated, so that stuff is more than likely solidified in the EGHE, as well as other areas of your coolant loops....
  5. Mendel Leisk
    42,349
    #5 Mendel Leisk, Jul 18, 2026
    Air_Boss likes this.
  6. ETC(SS)
    7,557
    Well...at least the OP was warned about it.
    Good info on the 'fix to the fix.'
    Mendel Leisk and Air_Boss like this.
  7. Sharnold
    409
    126
    Alabama
    I think I failed to explain that after the headgasket was replaced and a new thermostat and water pump was installed it was working flawlessly for a month
    Including the heat working
    It just now started doing this........
    Now we can go from here
    Sorry in advance leaving out that information
  8. rjparker
    11,113
    6,972
    New parts fail especially if they were aftermarket. Many have reported short lives of aftermarket water pumps.
    No heat means no flow through the heater when you also have an overheating situation.
    You are risking the engine if you have 248f at the first sensor.
    Monitor the two engine temperatures, ideally with graphical trends and you can isolate.
    Verifying the flow and debris at the bottom of the radiator as suggested above is useful. Especially if you can't monitor data.
    Sealer can clog systems - its not theoretical
    Prius gen3 stop leak at reservoir 2 sealer.jpeg Prius gen3 stop leak at reservoir sealer.jpeg
  9. Sharnold
    409
    126
    Alabama
    Monitoring was done via live recording on techstream pulling the mountain watching the water pump and electric fans working correctly but the temperature rising
  10. rjparker
    11,113
    6,972
    225f is hot for the first temp sensor but you are not monitoring the second temp sensor described above. Its the one that coded.
    Are you seeing flow into the reservoir?
    Don't forget no flow into the heater.
  11. Sharnold
    409
    126
    Alabama
    On techstream where would I monitor that other sensor
    It's not listed in motor ecu
    Also zero flow movement
    Also yesterday after recording reservoir was under pressure and full today after cooling is a little over half empty
    No headgasket failure I'm guessing boil over from the cap
  12. Sharnold
    409
    126
    Alabama
    Also a new development lol
    My reservoir cap fell apart
  13. rjparker
    11,113
    6,972
    A bad reservoir cap needs replacement. However it won't cause 248f warning light overheating by itself. It won't cause no flow into the reservoir or through the heater.
    I have mentioned twice above the other temperature is in the Combination Meter part of Techstream.
    Zero flow movement is not a big concern? Assumptions are killing your engine.
    A half empty reservoir in one day is not likely from cap relief. Its being vaporized by a bad hg leak (sometimes from loose head bolts or a warped head / block) or by a leak through the (wait for it) the exhaust heat recirculation system. You could be half empty in the entire cooling system.
    With a diy hg repair and sealer, normal gen3 hg symptoms may not apply.
    With no reservoir flow you are a) not viewing it properly when warmed up or (b) something is seriously blocked or (c) the water pump impeller is toast.
    I would suggest towing it to a dealer and stop assuming. My guess is you are not totally conversant with the cooling system flows or how the exhaust heat recirculation fits in.
    It might help to reread this thread, take notes and research things you need more insight into. When we can't even find out if the water pump is aftermarket because of assumptions (?) we are less than effective.
  14. BiomedO1
    4,608
    2,416
    Left Coast
    Did you flush out the cooling system before or after the head gasket was done?
    You've lost a few points when you tell us it was running flawlessly for a month, yet your operating temp. is 225F????? It should be around 185F; so you probability popped the head gasket again by running it hot and/or warped something. Clogged cooling channels will cause hot spots everywhere and may block super hot coolant from touching the sensor. So you think everything is running great; until the dummy lamp lights up.....
    Did you check for warp while doing the head gasket; since the previous owner obviously drove it like that for a good long while???? As I've stated before; the only time I'd take a gen3 is if it's FREE and looks good.
  15. Sharnold
    409
    126
    Alabama
    Ok guys..........
    I bought the car for less than 1k with a new hybrid battery and new tires.
    The only loss here is nothing even if I part it out.
    I.....me a mechanic fixed the headgasket along with replacement of wait for it
    The water pump and thermostat along with all seals gaskets and headbolts
    The head is not warped and was completely tested before use and wait for it........ refurbished
    There is zero headgasket leaks currently it's been pressure checked after it happened with inspection of the cylinders with a bore scope after a cooling down leak down time on the aluminum head for 12hrs after the last drive I recorded
    First time was using a Bluetooth app and a obd2 wireless adapter to monitor while driving as I do with all 5 of my personal vehicles
    Second time was only for the initial recording through techstream
    No I didn't see where you said to use techstream under combination meter above so that's my mistake before I did a recorded drive.
    Yes the cap needs replaced of course it does
    Water pump and thermostat is Asin not aftermarket junk nor Amazon refurbished or fake branded.
    Flushed....... somewhat considering there's no way on these to truly flush the system completely out especially the heater core or settlement of sealant
    I'm cooling system versed along with diverting coolant on quite a few due to a faulty heat exchange valve or a leaking heat exchange canister
    Headgasket jobs are my forte when it comes to lack of egr maintenance
    If I'm asking a question as one mechanic to another I'm looking for solutions I've never ran into and sometimes I'm posting while just spit balling ideas
    #15 Sharnold, Jul 19, 2026
  16. Sharnold
    409
    126
    Alabama
    I literally have an 08 model with a 4" suspension lift with a rebuilt motor and trans currently as my own favorite project 20240229_121112.jpg 20250707_125140.jpg
  17. rjparker
    11,113
    6,972
    Stop and spit ball this issue:
    No flow through reservoir or heater.
    As you are a mechanic you know the reservoir is not an overflow tank; its part of the circulation when the thermostat opens assuming the pump works.
    As an experienced guy you know stop leak clogs up flow and counterfeit water pumps are sold with genuine packaging.
    No flow in reservoir or heater. Oh well...
    Possible excessive heat in exhaust heat recirculation system
    Excessive coolant loss overnight
    BiomedO1 likes this.
  18. Sharnold
    409
    126
    Alabama
    Thank you for the response
    I'm seriously thinking a chunk of sealant broke loose somewhere and I might as well pull the system apart
    Good thing I use a automotive paint strainer filter in a funnel when I drain the system
    The pink stuff ain't cheap no more lol
  19. BiomedO1
    4,608
    2,416
    Left Coast
    You can reverse flush the heater core & EGHE, tie a panty hose on the exhaust end to see if you blow out garbage. Just because the coolant pump is turning; doesn't mean there's flow. Did you forget about the stop leak???
    Did you run a straight edge on the aluminum block? It's really soft material when compared to those old iron blocks - so it doesn't take much effort to blow a dip into the block; when someone is using stop leak to bridge an issue. You know they've been abusing and running that engine HOT.
    As a former mechanic, you figure things out and TEST - NOT guess and assume. Otherwise you'd be losing time and money; if you guess wrong; especially if it's a customer's car......
    #19 BiomedO1, Jul 19, 2026
  20. Sharnold
    409
    126
    Alabama
    Ok I finally got around to diagnosis before I strip the car down.
    After replacement of fluids and a new cap I ran the car in maintenance mode until 195⁰ to allow the thermostat to open.
    The engine coolant temp was 195⁰ on the ECT screen
    The engine coolant temp on the EHRS combination meter side was at 145⁰
    After removing the reservoir cap and manually turning on the water pump was instant overflow verifying the water pump is in fact operational.
    Shoot me some ideas in which to follow even if its draining the whole system and systematically removing everything individually
    Ty in advance
