Struggles uphill
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Gloria&Suzanne, Jun 28, 2026.
  1. ETC(SS)
    7,518
    Guys mature?
    Brian1954 likes this.
  2. BiomedO1
    4,550
    2,393
    Left Coast
    Yes; gen3 has an electric water pump and the CEL does NOT record or set a code for an over-temp. event. All you get is the temp lamp in your dash that triggers around 248+F. On rare occasions, the water pump may throw an under or over speed code; but that's usually due to air bubbles in your cooling systems. You should monitor it with a P10 HUD. I believe that rjparker has pictures of his setup.
  3. Brian1954
    Brian1954 Senior Member
    2,668
    1,066
    South Central PA, USA
    The answer to your question is yes, the engine water pump can go bad without triggering a trouble code. See the link provided by rjparker in post #4.
    #43 Brian1954, Jul 21, 2026 at 6:57 PM
  4. ChapmanF
    18,993
    Depends on the event: there can be a P0117 code, which means there was a reading from the sensor, at one point, for at least half a second, that was so extreme the ECU thought it might be a wiring short and not a real reading.
    Which it can be sometimes. But if you ever get that code and before you know whether it was a wiring short or a real reading, you should not delay trying to find out.
  5. rjparker
    11,045
    6,922
    It does look like coolant seeping but it could be spills as well.
    Obviously if you are losing coolant in the passenger side reservoir would escalate need to focus on the problem.
    I would probably get some brake clean and remove the residue to see if its a current leak.
    Knowing how the coolant temperatures are doing in realtime is very useful.
    BiomedO1 likes this.
  6. Mendel Leisk
    42,302
    Cars used to have a rudimentary coolant temp gauge. My ScanGauge could show temp; unfortunately it was the likely culprit in an escalating series of braking anomalies (Check Hybrid System warning, brake/traction lights, and work-to-rule braking ). Had to disconnect it. :(
  7. ChapmanF
    18,993
    Your ScanGauge must have had a bad upbringing. Mine's been plugged in for 16 years and been fine.
  8. Mendel Leisk
    42,302
    Yeah, apparently something flakey with the OBD port, possibly exacerbated by the constant mass, inertia of the plug. Seemed like the cascade of errors commenced with going over some sort of bump. Not sure though.
    Remember driving daughter-in-law's Sunfire to Costco for a gratis flat repair, muttering "even this $hit-box has a coolant temp gauge".
  9. ChapmanF
    18,993
    The cable I have plugged in at the DLC3 connector has a low-profile 90° plug with the cable coming out the side. I don't remember if that's the one that came with the ScanGauge or is one I bought. But because of the shape it probably puts less bouncing force on the connection than you'd see from a plug sticking straight out.
  10. Mendel Leisk
    42,302
    think I can find mine... :unsure:
  11. rjparker
    11,045
    6,922
    Many newer cars have a temperature gauge and the vast majority are never needed. I have never needed my P10 obd2 gauge on the v. It did alarm once when the reservoir cap was left loose but never rose higher than 220f.
    It is likely the scangauge was defective and causing a form of CAN Bus broadcast storm, eg a repeating high priority message blocking other traffic. I would have replaced the device.
  12. CR94
    CR94 Senior Member
    2,823
    1,238
    Northwestern S.C.
    Same here for 11 years, as far as any adverse impacts on the way the car operates. However, the left side of the display his been intermittent for the past 10 months, and it shows phantom fuel consumption in one circumstance.
  13. douglasjre
    douglasjre Senior Member
    2,249
    751
    Null, NL
    Don't include me in that self-deprecating gesture
