I hope there is a special level of hell dedicated to the engineers that designed the engine bay on the 2010 Prius. Coolant temperature sensor went on my wife’s DoorDash car. A $28 part and should be a 20 minute job. Have half the engine bay dismantled and still can’t get leverage on the safety lock button on the plug end to get the frakin thing to disengage so I can get a socket on it and I only have the good non slip crows foot wrenches so I can’t even slip a crows foot wrench on to turn and expose the button. May a million sand fleas from a leapers camel infest their crotches for eternity anyone got any tricks on pushing the release button when it’s at 6 o’clock and crusty from 16 years of working? Can’t find my grinder or else I would cut the “safety tabs” off my 3/4 crows foot and just break it loose to better access
I'm just get used to a really cheap 2010 with similar thoughts... Every time I look into it I find more stuff that needs to be fixed. So different than Gen2 Prius that hardly has anything wrong with it.
Is there more than one sensor? Just browsing the Repair Manual, is it this one, in the junction with white (air-release) cap on top, at a hose juncture above the EGR components: For another bone-head access issue, I'd nominate the inverter coolant pump: short of some metalwork, you need to remove the effing inverter to get to it.
There are two, your pic is downstream of the exhaust heat recirc system This one is at the large engine to radiator hose
Might be a bear getting the handles down there, so much in the way. I “think” this is it: (For reference, junction of EGR valve/cooer just above)
Except he has The trick is to hold it down while wiggling it side to side. It will quickly release with little damage except to your hand if you are forcing it when it gives.
ended up dropping $30 at autozone for the removal pliers. Took bolts out of the inverter coolant tank and the wife used the pliers and had it off in 10 seconds. At 53 she wanted to learn auto mechanics and every job we do she embarrasses me by removing stuff I loosened for an hour lol
Baby (our second gen) is a dream to work on compared to tink (our third gen) have you changed the coils and plugs on your gen 3 yet lol. It was so thoughtful of the engineers to make sure you make sure to inspect (remove) the entire wiper rack to do what should be a 10 minute plug change
The engineers were giving you wiper assembly muscle memory so its only 15 minutes of your brake booster, egr cooler or head gasket job.
