Stripped threads on Front Suspension Member Front Brace.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Derek Benham, Jul 20, 2026 at 11:21 PM.
  1. Derek Benham
    Derek Benham New Member
    Monday
    Utah
    Long time reader, first time poster. I appreciate all the knowledge within this community!
    So awhile ago I replaced the front stabilizer bar bushings on my 2010 Prius. When reinstalling, I don't know how it happened, but I stripped what one of the retaining bolts screws into. I could turn it until it sat flush with the brace but I couldn't torque it to spec without it getting more loose so I stopped messing with it. I think I was about to torque it to about 27 Nm (20ft-lbs).
    It was a late night and I guess I figured because I was able to torque down the other 3 to spec it'd probably be fine. Anyways, I somehow forgot about it until just a couple of days ago and figure I should get around to repairing that.
    I'm seeking confirmation on how I'm planning to repair it. First I was going to see if I could repair the threads by tapping them with the original size. If that doesn't work, I was planning to drill it out and tap in a helicoil. Is there a different way I should approach this?
    Also, does anyone know what size threads it is? I did some digging online and think the part number for the bolt is a 91552-L 1230, but the local Toyota dealership doesn't have it in stock and couldn't tell me any info about size, thread count or grade.
    And finally, please tell me if I'm an idiot and I need to repair this asap. I may have put 2000+ miles on it since doing this "repair", so I figure it's been fine this long, but I could be overlooking something (like structural integrity if I got in a crash).
  2. Derek Benham
    Monday
    Utah
    Ok, so I went out and checked on it again, probably should have done that before posting. Three of them were torqued to spec at 67 ft-lbs, the fourth (see arrow) was not at torque and spun a little. I remember from before that I wasn't able to ever get it to spec without it still spinning and I didn't want to damage it further.
    I slowly incremented my wrench and got all the way to 64 ft-lbs. So I'm going to say it's fine and I'm not going to mess with it unless I need to take off the front stabilizer for any reason in the future.
    I am still curious to know how any of you would repair the threads on the Lower Suspension Arm sub assembly, would you try to repair the threads or replace the full assembly?
  3. Mendel Leisk
    42,296
    I would go with that.
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,569
    2,602
    Taylors, SC
    I would remove the bolt, coat the threads with blue Loctite and reinstall it.
    Should the captive weld nuts ever break loose, the only viable repair would be to replace it with a rivet nut.
    The original bolt has J.I.S. 1.25 pitch threads. Although they are available, they are very expensive and so is the required tool.
    Standard rivet nuts are available only in 1.5 pitch threads. So the bolt needs to be replaced too.
    For more retentive power, I'd coat the rivet nut with JB Weld when installing it.
    #4 Georgina Rudkus, Jul 21, 2026 at 11:54 AM
  5. Mendel Leisk
    42,296
    Just to clarify: a non-permanent thread lock?
  6. ChapmanF
    18,977
    I'm afraid any thread-lock used on a bolt into a broken-off weld nut qualifies as permanent thread-lock. :)
  7. Mendel Leisk
    42,296
    I was wondering too: it for certain is a welded nut, not a threaded hole?
  8. Georgina Rudkus
    3,569
    2,602
    Taylors, SC
    It's a weld nut. It's in sheet steel.
