Coolant temperature sensor blues
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Wrecit, Jul 18, 2026 at 7:47 PM.
  1. Wrecit
    Wrecit Active Member
    186
    114
    Pittsburgh
    2001 Prius
    I
    I hope there is a special level of hell dedicated to the engineers that designed the engine bay on the 2010 Prius.
    Coolant temperature sensor went on my wife’s DoorDash car. A $28 part and should be a 20 minute job.
    Have half the engine bay dismantled and still can’t get leverage on the safety lock button on the plug end to get the frakin thing to disengage so I can get a socket on it and I only have the good non slip crows foot wrenches so I can’t even slip a crows foot wrench on to turn and expose the button.
    May a million sand fleas from a leapers camel infest their crotches for eternity
    anyone got any tricks on pushing the release button when it’s at 6 o’clock and crusty from 16 years of working? Can’t find my grinder or else I would cut the “safety tabs” off my 3/4 crows foot and just break it loose to better access
    PriusCamper likes this.
  2. PriusCamper
    PriusCamper Senior Member
    13,417
    5,416
    Pacific Northwest, USA
    I'm just get used to a really cheap 2010 with similar thoughts... Every time I look into it I find more stuff that needs to be fixed. So different than Gen2 Prius that hardly has anything wrong with it.
  3. Mendel Leisk
    42,293
    Is there more than one sensor? Just browsing the Repair Manual, is it this one, in the junction with white (air-release) cap on top, at a hose juncture above the EGR components:
    For another bone-head access issue, I'd nominate the inverter coolant pump: short of some metalwork, you need to remove the effing inverter to get to it.
  4. rjparker
    11,031
    6,919
    There are two, your pic is downstream of the exhaust heat recirc system ehrs flow and sensors partial.jpeg
    This one is at the large engine to radiator hose
    #4 rjparker, Jul 19, 2026 at 11:58 AM
  5. Mendel Leisk
    42,293
    Thanks, yeah, I was thinking as much.
    #5 Mendel Leisk, Jul 19, 2026 at 12:00 PM
  6. rjparker
    11,031
    6,919
    You can buy a connector removal tool or a set that holds the clip down while you wiggle it off.
    CR94 likes this.
  7. Mendel Leisk
    42,293
    Might be a bear getting the handles down there, so much in the way. I “think” this is it:
    (For reference, junction of EGR valve/cooer just above)
  8. rjparker
    11,031
    6,919
    Except he has
    The trick is to hold it down while wiggling it side to side. It will quickly release with little damage except to your hand if you are forcing it when it gives.
  9. Wrecit
    186
    114
    Pittsburgh
    2001 Prius
    I
    ended up dropping $30 at autozone for the removal pliers. Took bolts out of the inverter coolant tank and the wife used the pliers and had it off in 10 seconds. At 53 she wanted to learn auto mechanics and every job we do she embarrasses me by removing stuff I loosened for an hour lol
  10. Wrecit
    186
    114
    Pittsburgh
    2001 Prius
    I
    Baby (our second gen) is a dream to work on compared to tink (our third gen) have you changed the coils and plugs on your gen 3 yet lol. It was so thoughtful of the engineers to make sure you make sure to inspect (remove) the entire wiper rack to do what should be a 10 minute plug change
  11. rjparker
    11,031
    6,919
    The engineers were giving you wiper assembly muscle memory so its only 15 minutes of your brake booster, egr cooler or head gasket job.
  12. Mendel Leisk
    42,293
    I’ve still got one cowl bolt I could not find a location for. The other dozen or so should suffice.
  13. ChapmanF
    18,974
    Just keep it around for the next time you have the cowl off. You'll probably spot where it goes then,
  14. Mendel Leisk
    42,293
    Oh, I have a Prius box. Put labelled twist-ties on such. Also contains the EGR cooler lower bracket nut/stud combo, an extra PCV hose (current one cut for oil catch cans), extra O-rings (for aforementioned OCC's), extra aftermarket socket-head cap screws for the EGR valve cap, teeny packs of anti-seize, extra plastic fasteners, you name it.
    Still, when reinstalling the cowl, I looked it over exhaustively, could not find a missing bolt location. It's a distinctive bolt too, galvanized IIRC. Ah well...
