EGR Cooler "Nightmare Nut" Removal
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sage C, Jul 22, 2026 at 2:04 PM.
  1. Sage C
    Sage C New Member
    Yesterday
    Pennsylvania
    Hi! I'm working on taking apart my 2010 prius EGR system, I have the intake manifold, throttle body, the EGR metal hose that attaches to the intake manifold, and I have all the nuts/studs off, *except* the nightmare nut underneath the cooler. Does anyone have any tips on the length of wrench, length of socket, *anything* that can help me get this dang thing off?
  2. PriusCamper
    PriusCamper Senior Member
    13,420
    5,418
    Pacific Northwest, USA
    You can check @Mendel Leisk posts as he has links on how to do that job in the signature line of all his comments. His suggestion for that nightmare nut is to work on getting that one loose prior to the day of doing the job. I'm about to dive down into the Gen3 EGR rabbit hole and start doing them regularly and my plan is to have a clean EGR and cooler ready to go so I just swap them rather than having to soak and wait for them to be clean... Seems like that's the strategy of more than just me, lol...
  3. Sage C
    Sage C New Member
    Yesterday
    Pennsylvania
    Thanks for the suggestion!
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,569
    2,602
    Taylors, SC
    As I recall, it is an external torx net, either an E8 or an E10.
    External torx nuts are commonly used in German cars like BMW and Mercedes.
  5. Sage C
    Sage C New Member
    Yesterday
    Pennsylvania
    Yeah, the stud is an E8 torx, the nut is a 12mm. I can't figure out how to reach any of it with or without any of the wrenches or extensions I have. Was hoping for explicit suggestions of how someone else reached it.
  6. ChapmanF
    18,977
    It's a run-of-the-mill hex nut.
    The stud it goes on has an external Torx end, so that you also have a way of removing the stud.
  7. rjparker
    11,038
    6,920
    You take the nut off first and then remove the threaded stud with an E8 external torx socket on a 1/4" drive. Pulling the orange cables out of the way is reported to help gain access.
    The hex nut has to come off first. Recently one guy managed to break the stud off trying to use the torx socket without loosening the nut.
  8. ChapmanF
    18,977
    You could get the nut loose by a turn or two and then remove the stud with the nut still on it using the E8 bit.
    You just shouldn't try turning the stud when the nut is jammed down tight.
  9. Mendel Leisk
    42,296
    I would leave both the nut and stud off, permanently. If selling or trading in the car, “maybe” reinstall. With them off, the cooler can be extracted without removing the two studs at exhaust manifold, which keeps the gasket there from falling, and makes alignment during reinstall dead simple. You do need to loosen the mounting bracket of a tube running above, channeling gas tank vapour back to intake manifold iirc. It slightly obstructs the cooler as you pull it forward.
    I’ve cleaned the EGR system on our ‘10 a couple of times now (with relatively low miles, so not that bad), opted to just clean the existing cooler. It’s good to get it out, one end corked (smaller end is ~21 mm ID), filled with cleaner and propped up in corner of laundry sink ASAP.
    Let it soak about an hour, rinse and repeat-till-clean, while dealing with the rest of the system. Both times I used a concentrated solution Oxi-Clean Stain Remover (powdered laundry additive. Next time I’m considering to use a comparable approach but with 20~30% (by weight) potassium hydroxide (KOH) solution, see how that goes.
    Sodium Hydroxide (NaOH) would be comparable, but harder to obtain these days, due to its use in methamphetamine production I believe. Potassium Hydroxide has similar efficacy, and is commonly used in soap making. Sodium hydroxide is present in readily available oven cleaner sprays, albeit relatively dilute I think.
    Do use appropriate safety precautions with either; they’re strong caustics. Also, only use such caustics on the cooler: it’ll react with anything other than stainless steel or plastic, ie regular steel (such as the embedments on the intake manifold) or aluminum (the body of the EGR valve). It could be used on the stainless steel EGR pipe (between EGR valve and intake manifold) but it’s overkill. Brake cleaner, brushes and rags will suffice for those.
    there’s more EGR cleaning information in my signature (on a phone turn it landscape to see signatures)
    #9 Mendel Leisk, Jul 22, 2026 at 11:39 PM
