  1. ChapmanF
    18,985
    I have never once had any caliper pin from this car out of its rubber boot and bore.
    When I do my regular brake inspections, I push and pull them until they move freely again, and confirm that the motion feels smooth and greased.
    If I ever notice otherwise, that's when I'll take one out and clean it and regrease it. Hasn't happened yet.
    On PriusChat, for whatever reason, those pins have some odd status as the first or even only things mentioned for any caliper problem, as if they're the only caliper parts everybody has heard of.
    I have more often found cause to replace the "fitting kits" (a/k/a support plates) when they lose their factory Teflon-ish coating, then start to rust and interfere with pad motion. Even that not very often.
    James Analytic likes this.
  2. douglasjre
    douglasjre Senior Member
    2,247
    751
    Null, NL
    I have concerns that paint may cook off causing a wheel to come loose l. I also believe that paint prevents heat transfer to the wheel which is the radiator for the rotor. What are your thoughts?
  3. ASRDogman
    ASRDogman Senior Member
    8,053
    4,083
    Yeaaa, oil them there brake pads really good! Oil everything on them there brakes....
  4. ChapmanF
    18,985
    Well, Toyota does paint the outer surface of the 'hat' where the rotor contacts the wheel. They must think it's ok.
    Difference is, some aftermarket rotors also paint inside the hat, where the rotor contacts the hub bearing assembly. Not sure why Toyota doesn't, but I doubt it's from a desire to dump heat into the bearing.
    I'm not sure to what extent the wheel is an important radiator for the rotor either, at least for front rotors that have cooling vanes right through 'em.
  5. Bohemian Grove
    55
    35
    Over 3 years after buying the polarization film, I finally inverted the LCD. Thanks to @hoffeck for the inspiration! IMG_3109.jpeg
    hill likes this.
  6. robpia
    robpia New Member
    Today
    La Puente
    Hi Chat!
    Today I will start parting out my car I've owned since 2013. So do watch out in the Private Sales for items I'll be posting! I need to put this car back to Stock form. So everything will go. Wheels, headlamps, tailamps, air suspension, etc. Reach out!
