Is the pic showing blown head gasket?
Discussion in 'Gen 3 Prius Technical Discussion' started by David Wallace, Jul 25, 2026 at 1:31 PM.
  1. David Wallace
    David Wallace New Member
    Friday
    Charleston
    Hello,
    Wanted to ask for your help diagnosing potential head gasket on my 2013 Prius at 220K miles.
    *Please see attached view in cylinder 1 where I think I see coolant droplets?
    symptoms
    - slowly losing coolant from reservoir can’t find external leak
    - started with misfire (rattle) on cold starts then progressively moved to misfire shudder for 1-3 seconds every stoplight once engine heats up - otherwise drives normal avg 45-50 mgs
    - no codes (but did have p301 cyl 1 misfire months ago)
    - cyl 1 spark plug looked either lean or maybe a tiny bit washed
    tests
    - compression (cyl 1 - 120 with other 3 between that up to 130)
    - exhaust gas reservoir test (passed)
    -ignition coils passes
    What I’ve done
    - cleaned egr valve, cooler, pipe, and intake manifold
    - new spark plugs, air filter, oil change with filter, air filter
    - new injectors
  2. Mendel Leisk
    42,305
    Was that the first EGR cleaning?
    QUOTE="David Wallace, post: 3620940, member: 223720"]started with misfire (rattle) on cold starts then progressively moved to misfire shudder for 1-3 seconds every stoplight once engine heats up - otherwise drives normal avg 45-50 mgs[/QUOTE]
    Very likely coolant in combustion chambers.
    #2 Mendel Leisk, Jul 26, 2026 at 3:28 PM
