Fluctuating coolant levels
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Travisfixingaprius, Jul 27, 2026 at 8:19 AM.
  1. Travisfixingaprius
    Travisfixingaprius Junior Member
    34
    US
    im trying to understand what I see here. Vertically, half the tank is full. The other side appears empty.
    then, I drive 7-8 miles it re-appears again.
    I initially thought I was having a coolant leak. But it doesn’t appear so. I had been hearing lots of sloshing on ICE every time in park or while driving so I checked it. Seen it was low like this, I fill it, but this cycle keeps continuing of an appeared to be empty half of tank to not being empty.
    Still not sure if this is a coolant leak.
    I’ve had heat exchanger swapped before. I’m not having any type of car symptoms or heat issues.
    Also, the coolant mess you see in photo 1 is from an intentional overflow. Someone was filling it and simply made it a mess. Photo 2 I wiped down during same hour.
    the coolant slosh became noticeable before I even opened coolant cap once.
  2. Travisfixingaprius
    34
    US
    I want to add: the person overfilled my tank. And currently, it doesn’t appear overfilled anymore.
    any recommendations to consider here? Not seeing any coolant loss, or issues with car.
