2025 Unplugged Valve Cover Vents??
Discussion in 'Gen 5 Prius Main Forum' started by SXP, Jul 26, 2026 at 7:43 PM.
  1. SXP
    SXP Junior Member
    37
    Huntington Beach, Ca
    2025 Prius
    Could someone look under their hood and see if these three "vents" are supposed to be open to the atmosphere, or should they have hoses or plugs connected to them. Thanks. PXL_20260726_233228497.jpg
  2. ChapmanF
    18,995
    Are those the standoffs for a decorative cover that sits on top of the engine, that might be missing on yours?
    Brian1954 likes this.
  3. Hammersmith
    Hammersmith Senior Member
    2,472
    2,532
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Those are indeed the places where an engine cover goes. The cover has rubber rings that hold onto those tubes. But the M20A in the Prius sits too far under the cowl for any engine cover to fit. The only M20A I found that uses a cover is the Lexus UX series.
    Back in 2023 when I bought my gen5, I ordered one to see if it would fit. If it had, I was going to modify it a bit to remove the Lexus badging and replace it with Toyota badging. But it only took a few minutes to realize the plans were futile.
    There are only three connection points, and one is right under a heat shield(the one in OP's first photo). There's no way to modify the engine cover to fit without removing that connection entirely. And the cover wouldn't be stable with only two connection points. So now I've got a UX 200 engine cover sitting on a shelf in my garage for the last three years. lol
    As for why the Prius(and Corolla) valve cover has points for a engine cover it doesn't have, it's because it's cheaper to just make a single part that works on all M20A engines.
    This is what the M20A in a UX looks like:
    I bought a UX 200 cover that didn't have the hybrid badge. I planned to paint the whole thing one or two shades of matte black for more of a Toyota look, and I was going to pry or grind off the Lexus L and find a chromed Toyota T logo of about the same size and glue it on.
    I believe it was the gen3 where you could dress up the engine bay with parts from Toyota Japan as well as some parts from the Lexus CT(OEM hood struts, coolant tank covers, engine cover, etc.). I was hoping to do something similar to my gen5, but the spaces are just too tight.
    #3 Hammersmith, Jul 27, 2026 at 12:58 AM
  4. PriusCamper
    PriusCamper Senior Member
    13,435
    5,422
    Pacific Northwest, USA
    I heard there's lots of different super expensive Legos Minifigs that fit on 'em...
  5. SXP
    SXP Junior Member
    37
    2025 Prius
    Thanks guys. I guess I could have stuck a screwdriver down one of the tubes to see if it passed through or not....
  6. ChapmanF
    18,995
    It does, if you stick the screwdriver down hard enough. :D
  7. Mendel Leisk
    42,310
    You’re not the first to ask btw. If cover is missing, or not used, it does look odd.
