IG2 "Ignition" Relay Location
Discussion in 'Gen 2 Prius Technical Discussion' started by Ian McMillan, Jul 28, 2026 at 12:02 PM.
Tags:
  1. Ian McMillan
    Ian McMillan New Member
    Yesterday
    South Africa
    Hi there, 2006 Prius (Gen-2): does anyone know WHERE the IG2 "Ignition" Relay is located? - Something is draining my 12V battery, when I pull the AM2 ("Ignition") fuse, the problem ceases - 1st suspect is a jammed IG2 Relay, but I can't find it! - Thanks in advance..
  2. Ian McMillan
    Yesterday
    South Africa
    Update: OK, I've established that it's (apparently!) part of a 'Integration Relay Unit' comprising a PCB which apparently sits underneath/behind the main fuse block.. will strip it tomorrow & verify
