Brakes making weird noise and lights came on
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Aaron Williams, Jul 28, 2026 at 11:36 AM.
  1. Aaron Williams
    Aaron Williams Junior Member
    Tacoma, Washington
    Hello fellow Gen 2 prius owners,
    I have a 2009 Toyota Prius 158k miles. Over the weekend the Brake light, and brake warning light, ABS light, and traction control light flipped on. It has brake fluid, but I haven’t noticed any difference in brake performance. In addition, it has been making some clucking sounds like a chicken when I step on the brake, it’s louder if I step on it harder. Any thoughts on the problem?
    52,819
    the sound is coming from the actuator and fairly common on older prius. you'll need a prius aware scanner to read the trouble codes.
  3. Aaron Williams
    Tacoma, Washington
    Okay, I’ll look into that. My friend has a fox well NT630 plus he said he would let me borrow. Based on fox wells website it looks like it is compatible. If not, any recommendations on code readers?
    also, I found a service bulletin for a different abs actuator then the original but I can’t seem to find any of the replacement actuator.
    TSB T-SB-0032-16
  4. ChapmanF
    18,999
    The scan tool makes it easy to read the codes, but you can get brake system codes without it: Blink (a/k/a Flash) Codes – How to. | PriusChat
  5. bisco
    52,819
    autel is supposed to be pretty good with prius, I haven't used it. there's a thread here, but search is broken.
    maxiap-ap200
    you can get it from amazon
  6. rjparker
    11,065
    6,934
    Replaced with 04003-44647
    Sometimes additional online Toyota dealer discounts up to 25% are available around federal holidays. The next would be the week before Labor day.
    Shops with accounts can often get big discounts from the local dealer if you know someone at such a shop.
