code p3102 and intermittent triangle of DOOM
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dogChair, Jul 3, 2026.
  1. Brian1954
    Brian1954 Senior Member
    2,670
    1,068
    South Central PA, USA
  2. dogChair
    dogChair New Member
    orlando, fl
    alright, I went ahead and bought a new 12 volt battery after testing the car by jumping it off a good battery. The codes cleared like they always do when you disconnect the battery, but none came back except for the AC codes (B1421 sun sensor and B1442 air inlet damper control servomotor). only weird thing was when I tried to start it it lit up all the warning lights except for the triangle and wouldn't move. I plugged in the code checker and weirdly there were no new codes. Restarted the car and it worked fine this time. No clue what that was but I'm hopeful it's fixed!
  3. dolj
    dolj Senior Member
    8,640
    4,390
    Wellington, New Zealand
    This is normal behavior the first time after the 12 V has been disconnected. The first start after reconnecting the 12 V battery, press the start button twice. The first press illuminates almost all the warning lights, then the next press makes the car READY.
