PCV and CCV oil catch cans
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AzusaPrius, Mar 30, 2026.
  1. AzusaPrius
    AzusaPrius Senior Member
    2,257
    942
    I have brought this up in the forums before and I believe this to be the best oil catch can setup you can do.
    I used the best locations I could for this type of setup and the OCC I had.
    For the PCV catch can, I was inspired by a post from @sLick415 which gave the best location for a stealth setup for Cali smogs.
    Ther are a few others on here who have adapted this location and they are the following.
    @Tekken
    @tacopyro
    @HappyDad701
    @tri4all
    For the CCV I was doing research online and came across two images that show a catch can on the breather hose.
    This a vacuum on WOT which the prius is usually high rpms and I have a bored TB.
    So I have done a setup with both.
    I know @danlatu had some ideas with messing around with putting another PCV on the valve cover or relocating it to the breather hose.
    I managed to do this without removing the intake manifold and in the near future will be updating the intake manifold to the latest version.
    Stay clean!!! 20260324_130930.jpeg 20260324_131144.jpeg 20260324_131208.jpeg 20260324_131509.jpeg 20260330_151930.jpeg 20260326_140843.jpeg 20260326_140802.jpeg 20260326_142529.jpeg 20260326_140935.jpeg 20260326_142421.jpeg 20260326_142616.jpeg 20260326_142803.jpeg 20260326_143033.jpeg 20260329_122008.jpeg 20260329_121926.jpeg 20260329_121916.jpeg 20260329_122026.jpeg
  2. AzusaPrius
    2,257
    942
    Here is an example of what my setup is.
    Also two images of the internals of the oil catch cans I have currently, I do plan on changing them later on.
    Then a few images of others in Japan doing this on the CCV. unnamed.jpeg tapatalk_1775095985661-1.jpeg upr-billet-diffuser-for-billet-techonology-catch-can-3__96234.1511302051.1280.1280.jpeg 2060570_3.jpeg p1.jpeg 2060590_01.jpeg 2060590_03.jpeg
  3. AzusaPrius
    2,257
    942
    Last image was supposed to be this uploaded by @RightOnTime if I remember correctly.
    Before I saw this image I was thinking something like this type of setup for the CCV.
    #3 AzusaPrius, Apr 2, 2026
  4. AzusaPrius
    2,257
    942
    Here is a full image of the 3rd gen in Japan with a catch can on the CCV. tapatalk_1775183505966.jpeg
  5. Mendel Leisk
    42,332
    CCV is meaning Crank Case Ventilation? Maybe valve cover breather is more to the point?
    I don’t think there’s much (if any) oil coming from that. It feeds into the large diameter hose directly before throttle body, always been completely clean in my experience.
    the hose from PCV (Positive Crankcase Ventilation) is another story, that’s where I would invest in oil catch can, a quality one, or even two in series.
    those screw clamps on the barb connectors can be left off: the barbs alone are effective seals with properly sized hoses, and the clamps are detrimental to hose-end condition.
  6. AzusaPrius
    2,257
    942
    @Mendel Leisk
    Well it is a vacuum at WOT so....
    Im sure those guys in Japan know a little more about the Prius than us.
    Also it makes sense to me, but did you notice the PCV catch can?
    Nice n low like yours but pretty much directly under the PCV hose, so it made a nice vertical drop to the catch can.
    I drive pretty fast and the roads here are not well taken care of so I put the hose clamps on for security.
  7. Joele3
    Joele3 Active Member
    137
    205
    Bay Area
    Regarding catch cans. Here's a picture from the smog check manual. They do not require an EO verification for CA smog checks.
  8. Hayslayer
    Hayslayer Active Member
    534
    325
    Under "Hoses".....Wth is a performed hose? It's a shame that California can't spell "preformed hose" correctly.
  9. AzusaPrius
    2,257
    942
    Here is one more from Japan that I just recently found while searching.
    I was not going to upload my first version of my CCV setup but since I found this twin in Japan, I had to execept they are venting their catch can.
    I wanted the hoses to be shorter so I ordered one from Ebay that made the setup better.
    There is no other image like it other than mine only because we have the same warm air intake.
    First image is my setup and second one is the Japan prius.
    As far as smog inspection, it all depends on the tech really, for sure your catch cans have to be sealed. 20260324_155317.jpeg b8705c8e2c46ed85ea28bec6ae7787.jpeg
  10. AzusaPrius
    2,257
    942
    Updated the CCV catch can to a 30 micron brass inline filter.
    Looks much cleaner and the air flow is shorter than previous. 20260713_094940.jpeg
  11. Mendel Leisk
    42,332
    Is there still a pcv valve in the stock position (mounted on the wall of the block, below/behind the intake manifold), or is that just "deleted"?
  12. AzusaPrius
    2,257
    942
    Yes I left that in its stock location
  13. Mendel Leisk
    42,332
    Is there a catch can between the PCV valve and intake manifold?
  14. AzusaPrius
    2,257
    942
    You obviously did not look at my first post, there are pictures of the catch can for the PCV and location.
  15. AzusaPrius
    2,257
    942
    Updated the lower catch can with an inline 30 micron brass filter.
    That should take care of any remaining oils in the air as much as possible after it gets caught in the catch can 20260726_113952.jpeg 20260726_114026.jpeg 20260726_114048.jpeg
  16. Viviparous
    Viviparous Junior Member
    36
    Back in California
    2014 Prius v wagon
    I did something like this to my old ‘88 Toyota Corolla All-Trak wagon. I just put an inline (Purolator brand) fuel filter between the exhaust and the air intake. I donated the All-Trak when the transaxle failed, but I think I still have that filter mod in my garage somewhere.
    I never thought about an oil catch can at the time (circa 2010?) For some reason, I never thought about doing the same thing to the Prius. I wonder if an oil catch can would still be needed if the filter was regulary cleaned or replaced.
    Also, for those of us in California, would we have to remove the oil catch can, tubing, and filter before a smog inspection. I assume we would. For that old Corolla, I left that filter in and none of the smog techs mentioned it when I got the car smogged. But, perhaps smog inspections are stricter now.
    #16 Viviparous, Jul 26, 2026
  17. AzusaPrius
    2,257
    942
    My PCV catch can is placed way at the bottom and I most likely will not need to remove it, even if I put back the OEM air intake.
    Now the CCV inline filter Im not sure but maybe be able to leave it too, depends.
    I got a cool smog guy by me that may let it slide.
  18. Viviparous
    36
    Back in California
    2014 Prius v wagon
    Azusa, from where did you get the inline, brass 30 micron filter?
  19. AzusaPrius
    2,257
    942
    I got it on amazon
