Gen 3 P410 transmission differential tapered roller bearing spec
Discussion in 'Gen 3 Prius Main Forum' started by nettrinity, Aug 3, 2026 at 12:37 PM.
Tags:
  1. nettrinity
    nettrinity Junior Member
    I am trying to replace Gen 3 P410 transmission differential tapered roller bearing, but I can't find the spec. I had differential out, but the bearing is un-marked, no document available. Does anybody know this bearing spec?
    Here is the link to the image
    Image 20260803123444 19 87 — Postimages
  2. Mendel Leisk
    42,332
  3. Tombukt2
    13,853
    2,515
    The Toyota dealer can't look that up for you in 10 seconds no kidding
  4. Tombukt2
    13,853
    2,515
    Do this is for diff. Do it require set up bearing pre load and all that like a reg vehicle diff? All that set up procedures in the manual correct? I have it for other rear ends but not this.
  5. nettrinity
    Good illustration! Thank you! But I still can't find the tapper roller bearing spec on this illustration. Through physical measurement I found my roller tapper bearing is ID 50mm, OD 75mm, width 20mm. Not sure if it is enough. Anybody done this before?
  6. nettrinity
    No shim found in diff tappered roller bearing
  7. Mendel Leisk
    42,332
    Per post #3, dealership parts department?
  8. ChapmanF
    19,011
    The one you buy from Toyota will have the right ID, OD, width, roller pitch and taper, steel surface treatment, and every other particular that Toyota required of their suppliers for that part.
