Water Pump Replacement
Discussion in 'Gen 3 Prius Main Forum' started by Shank, Aug 4, 2026 at 8:11 PM.
  1. Shank
    Shank Junior Member
    Vermont
    I have a 2010 with 180k miles on it. I just wanted to get other people's thoughts on replacing the water pump proactively as a maintenance item before it fails. I'm not having any problems with it at all now, but I drive around rural Vermont a lot where a breakdown wouldn't be too great. I also worry about the engine overheating and a blown head gasket, but maybe I should just don't fix what isn't broken. The part is about $250 and I would do it myself. Thanks
  2. Merkey
    Merkey Active Member
    330
    305
    Birmingham, Michigan
    I had an overheating event that stalled my car at around 175,000 miles. After it cooled down I was able to drive it to dealer. A
    new water pump was installed and it has worked great ever since, but not a cheap repair. I would recommend replacement before it fails.
    Shank likes this.
  3. Brian1954
    Brian1954 Senior Member
    2,674
    1,071
    South Central PA, USA
    I recommend that you monitor the engine coolant temperature by using a display that connects to the OBD2 port. By doing this, you will know if the engine water pump starts to fail. The pump usually gradually goes bad. Then, you will have enough time to order a new pump and install it before the engine overheats.
    Merkey and Shank like this.
  4. CR94
    CR94 Senior Member
    2,829
    1,242
    Northwestern S.C.
    I try to pay attention to engine coolant temperature, especially on long uphills, when effects of an impaired pump would be most obvious.
    No hint of a problem with mine, so far.
    Shank likes this.
  5. rjparker
    11,087
    6,950
    Monitor and consider having the part on hand for the day it does happen.
    Don't buy an aftermarket water pump even though they are considerably cheaper and more available.
    If cost is a major holdup, consider buying a replacement impeller for an emergency repair.
    Brian1954 and CR94 like this.
  6. CR94
    CR94 Senior Member
    2,829
    1,242
    Northwestern S.C.
    How does the quality of that impeller compare to that of the original? Cost aside, is replacing it more or less laborious than replacing the whole pump?
    Thanks!
  7. Mendel Leisk
    42,341
    There's been reports of the engine water pump failing, around 150k miles. I've resolved to replace ours by 100k miles (if we ever get there), in conjunction with an engine coolant change.
    Probably will use the Aisin WPT-190, which I believe is the same pump, just not Toyota-branded. Amayama will have it on my doorstep for $173~ CDN.
    Then there's the inverter water pump. It seems to have more longevity, maybe not as taxed? Again, there's a Aisin equivalent, WQT-001, more reasonably priced.
    #7 Mendel Leisk, Aug 5, 2026 at 12:20 PM
  8. rjparker
    11,087
    6,950
    Reports are the impeller is the only thing that goes bad so I have one stored with the spare tire for use in an emergency. Various members have had success. The original quality casting and power electronics remain.
    If I had to install, it takes a simple socket wrench set to remove the water pump. You can tell by taking off the three bolt air intake how easy it is to access, even without a jack to get eyes on the bottom bolts.
    If nothing else, the impeller would provide time to buy a genuine part which might allow oem purchase at the next holiday sale.
    With 355,000 mikes my water pumps are original which I attribute to frequent coolant changes. With continuous monitoring and an early audible temperature alert, I am not worried about the pumps at this time.
