What would you do IF you had to replace your A/C evaporator-core?
Discussion in 'Gen 2 Prius Main Forum' started by priuslyfe, Jul 18, 2026.
  1. priuslyfe
    priuslyfe Member
    350
    71
    here's a good video of a guy checking the evap on a 2007 prius. he had to drill a hole in the case to look into the interior of the evap because it wasn't showing up with traditional methods.
    personally, i think bad evaporator suggests selling the car with full-disclosure. not sure its worth fixing unless sentimental value of car.
  2. priuslyfe
    priuslyfe Member
    350
    71
  3. rjparker
    11,093
    6,958
    Tom is a Priuschat member and uses a Prius c as a work vehicle (until recently when the head gasket blew). When a leak is so slow that a pressure or vacuum test passes, he would vacuum and add 16 oz of pure r134a which will last a season. Next year top off with perhaps 8 to 12 oz ($15 can at Walmart for diy) using the sight glass. A couple of years later the car is likely to be gone but the customer had ac until the engine blew.
    When the leak is bigger, Tom's $1000 refrigerant leak detector will pick it up at the vents or at the drain. A pressure or vacuum test on isolated refrigerant lines going to the evap will also fail which is positive. At that point some will pay the $2k if the rest of the 20 year old Prius is still viable.
  4. rjparker
    11,093
    6,958
