Battery ECU reporting erratic module voltages
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by NiallS, Aug 6, 2026 at 10:08 PM.
  1. NiallS
    NiallS Junior Member
    Brooklyn, NY
    Hey folks,
    Our Prius recently threw four hybrid battery fault codes (P3000, P3030, P3012 and P3013)
    Initially suspected modules 2 & 3 were failing based on P3012 & P3013. Then realized the ECU was reporting wildly erratic and physically impossible voltages for those modules. See attached chart showing modules 1 and 4 holding steady, while module 2 swings 10V to -15V, and module 3 swings +10V to 25V.
    Curious if anyone's seen this kind of fault before? My guess is the harness is corroded at the connector or module and/or the battery ECU is failing. Planning to open it up tomorrow to inspect.
    Thanks,
    Niall
    #1 NiallS, Aug 6, 2026 at 10:08 PM
  2. dolj
    dolj Senior Member
    8,645
    4,395
    Wellington, New Zealand
    I think you're on the right track, and I would be leaning toward corrosion in the sensing wires of the No 2 Frame Wire causing a break in one or more of the wires. I would replace the No 2 Frame Wire if this was the case, and if the corrosion reached the battery ECU plug, I'd clean the ECU pins or replace the ECU if the pins were too damaged.
    #2 dolj, Aug 7, 2026 at 6:53 AM
    Brian1954 and NiallS like this.
  3. NiallS
    Brooklyn, NY
    [mention]dolj [/mention] Thanks so much, good to know I am probably on the right track.
    ( If any members near Chevy Chase MD happen to have a used sensing harness or battery ECU for sale please shoot me a DM or reply here!)
    iPhone ?
  4. dolj
    dolj Senior Member
    8,645
    4,395
    A new replacement harness is available from ACENBAY for $85: Toyota Prius Hybrid Battery Wire Harness Assembly.
    Used ECUs are readily available from wreckers or eBay.
    #4 dolj, Aug 7, 2026 at 9:52 AM
  5. dolj
    dolj Senior Member
    8,645
    4,395
    @NiallS, try using the @ in front of a user's to 'mention'.
