Abnormally high compression?
Discussion in 'Generation 1 Prius Discussion' started by Iris_TheRainbow, Aug 9, 2026 at 3:17 PM.
  1. Iris_TheRainbow
    Iris_TheRainbow New Member
    Illinois
    2003 Prius
    While trying to diagnose why my engines running rough, I compression tested it and got numbers I wasn’t expecting.
    The spec for this car is 128psi, 99psi minimum, and 14psi max difference, but my measurements were very high, 150, 180, 180,and 180.
    180 is incredibly high. In fact, it’s right about the expected compression for a 13:1 engine, but it’s to my knowledge the 128 number represents the apparent 8.5:1 ratio from the Atkinson cycle engine. Obviously, the 150 number is too low in comparison, this is probably a bad piston ring, given my oil consumption and blowby.
    Am I missing something about the compression for this car? I did the math and would need over 8ccs of carbon buildup for the 180psi number to be right, which sounds improbable.
  2. ChapmanF
    19,025
    Do you think there could be an intake timing issue? The timing adjuster isn't working, or the chain is mistimed, or somebody worked on the engine and put in an intake cam from a different 1NZ?
    If I remember right, the Prius engine sort of mechanically is a 13:1 engine, if the intake valves close when an Otto engine would close them....
