looking for advice regarding head gasket
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TonyaT, Jul 21, 2026.
  1. TonyaT
    TonyaT New Member
    Arizona
    I'm looking for advice on whether I should pay $$$ to have my head gasket replaced. I have a 2013 Prius Persona with 220,730 miles and a confirmed bad head gasket. I've had the car since new and the only other major repair was a brake system failure which cost ~$1500 to repair which frankly Toyota should have covered since this particular failure was a known issue...anyway, I'm weighing if I should spend the money (est $2300-$4K) to replace the head gasket and hope to get another 2 years out of the car or if I should just sell it as is for next to nothing. Note- no other repairs so original lithium battery, water pump, etc. Thanks in advance for any advice on this and other tips.
    Gokhan and bisco like this.
  2. PriusCamper
    PriusCamper Senior Member
    13,465
    5,432
    Pacific Northwest, USA
    Getting another two years out of the car will be no problem with just the headgasket job. If you want to have the car for another 5-10 years though your high MPG pistons and rings are gonna start burning oil and I'd recommend http://www.skimmilkhybrid.com/ in Oklahoma. He rebuilds all the problems out of Gen3 engines for a very reasonable price.
    TonyaT and GcinFl like this.
  3. bisco
    52,858
    sounds like a lot of money for a couple years, but there's a difference between $2,300. and 4k, plus the quality of the repair.
    otoh, you could fix it, sell it, and use the money towards a newer car.
    TonyaT likes this.
  4. Mendel Leisk
    42,349
    If you go through with repairs, it’d be prudent to clean the EGR (Exhaust Gas Recirculation) system too, including the EGR passages in the intake manifold. It’ll be severely clogged with carbon; It’s my conviction that it’s the culprit in this all too common scenario.
    more info in my signature (on a phone turn it landscape to see signatures)
    how’s the oil consumption? That’s another factor to consider, when deciding how to deal with this engine.
    TonyaT likes this.
  5. Hammersmith
    Hammersmith Senior Member
    2,490
    2,548
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    (Very first thing: This is the subforum for the gen5(2023-27). You might want to repost or have this moved to the gen3(2010-16) subforum to get a wider range of responses.)
    The most important questions are:
    What's the current overall condition of the car?
    and:
    How well have you taken care of it over the last 14 years?
    What have you been doing for oil changes? 6m/5k, 1y/10k, something worse? Have you used good quality oil and filters or the cheapest? How about coolant changes? Have you done 5y/50k or have you gone longer? Transaxle fluid replacement; has it ever been done? Have you regularly checked your HV battery cooling fan filter and kept it clean?
    And what's the condition of the body? Any rust, damage from accidents, peeling paint, etc.? How's the interior? Are the seats torn, headliner sagging, big scratches or burns on the plastic? Have you had the suspension, brakes, engine mounts, etc. checked recently and what're their conditions? Even consider the condition of the tires. Are you going to need new ones soon or do you have years left on them?
    See, if you've taken care of it well and the car is perfect other than the head gasket, then it's probably worth getting fixed. But if you've done 10k mile oil changes(or worse), never replaced the coolant, never replaced the transaxle fluid, the body is showing signs of rust, and your seats are torn, then it's probably not worth it. Or if it only needs a head gasket now, but you get it inspected by a trusted mechanic and it's got a bunch of other stuff(struts, brakes, other major powertrain work) that's just about to go, then it might not be worth fixing.
    When you start getting into situations where the cost of the repair comes close to the value of the vehicle(especially on older cars), the overall condition of the car becomes the most important thing. Don't drop $3k-$4k or more on a car that's going to need another $2k next year, $5k the year after that, $1k six months after that, etc.
    At least that's my $0.02. Take it with exactly that much value. ;)
    Here's a video on this general topic from someone that works on dozens of Toyotas each week:
    TonyaT likes this.
  6. Hammersmith
    2,490
    2,548
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I expect the range of cost is because the mechanic won't know if the head/block is warped until they get it off. If the head and block are still within spec, then it's just a new gasket and button it up. But if something is warped, then those parts need to go to a machine shop to be fixed before it goes back together. It's bad enough if the head is warped, but if the block is warped, it really shouldn't be reused. Machining an aluminum, open deck block is not a great idea. And sanding it while it's still in the car is probably an even worse idea.
    And if the mechanic pulls the head and sees major scoring on the cylinder walls(very possible at 220k miles if the owner has been doing 10k oil changes and the rings are locked up), then it's really game over for the block. In fact, I'd want the cylinders boroscoped to check for possible scoring before spending any more money on it. Putting a new head gasket on a scored block is the definition of putting lipstick on a pig.
  7. rjparker
    11,113
    6,970
    For $3k or above I would replace the engine with a JDM used in Japan engine available in major cities through JDM distributors. Installed by a local shop, hopefully one who has worked on a Prius in the past. Assuming the nimh hybrid battery is not on its last legs
    TonyaT likes this.
  8. Tombukt2
    13,864
    2,519
    2 to 4K right now will get you a pretty nice generation two with high mileage but running well with most maintenance up to date etc. I was buying them pretty regularly for quite a while just recently had to stop failing hip . Going to be out of commission for several weeks when that gets replaced and so on I'm under construction at property. So I'm clearing stuff out of here on a fast track. and once that's done the next twenty will be on auto pilot I won't be worrying much with vehicles and transportations and aircraft and all that sort of thing I got all I need so . Ill hold
    TonyaT likes this.
  9. notspam3
    notspam3 Member
    138
    74
    Toronto
    2024 Prius Prime
    XSE Premium
    Don't give away that car - it's worth at least $1K scrap value for the catalytic converters
  10. TonyaT
    TonyaT New Member
    Arizona
    Thanks everyone for the advice! Here's my update which includes a new problem I would like advice on.
    Soooo I pulled the trigger and had the headgasket replaced for $2300 which included the full cleaning of the EGR valves as recommended here. Prior to the repair the water pump had been fine and the car was not overheating at all HOWEVER after they replaced the headgasket there was a code reported for the water pump (P261C) so I had that replaced too - the shop only charged for the part, not labor. I got the car back last Friday (it's Monday) and didn't drive it much at all over the weekend until Sunday and noticed a funny smell but I thought the engine might just burning off fluid that had spilled. Then I noticed something much more concerning, my gas milage was TERRIBLE!!! I always keep the 'miles until empty' meter engaged and it was going down twice as fast as it should have. I stopped at the gas station and then noticed some smoke rising from the hood, not a ton but definately noticable. Checked the oil level (shop said they replaced but I know shops can forget simple things) and it was full. Looking for advice why the fule appears to be burning excessively. I googled and it said it could be as simple as needing reset. I took the car back to the shop this morning and they are checking it out but I thought I would ask here as well. Thanks in advance for any knowledge/advice shared!!!
  11. rjparker
    11,113
    6,970
    Don't believe the cars calculated mpg. Fill up, record the miles, fillup later record the gallons bought and calculate the miles driven. Divide miles by gallons.
    Generally a smooth running engine will not be the cause of real mpg degradation.
    More likely real drops are caused by a failing hybrid battery. A 2013 could be easily weak without codes if its original.
  12. CR94
    CR94 Senior Member
    2,831
    1,243
    Northwestern S.C.
    Is it running well? Did you locate specifically where the odor or smoke was coming from?
