Best charging habits for Prius Prime battery life?
Discussion in 'Prime Plug-in Charging' started by HomeDIYer22, Aug 12, 2026 at 6:29 AM.
  1. HomeDIYer22
    HomeDIYer22 New Member
    Today
    Hongkong
    Four Touring
    为了长期保持Prime电池的健康状态,您推荐怎样的充电方式?是应该经常充满电,还是应该避免充满电?
  2. Tideland Prius
    16,681
    Set a departure time in the car’s charging schedule so that it can finish as close as possible to your departure to reduce the time it sits fully charged. Note that “full” in the battery meter doesn’t mean full in real state of charge as Toyota built in a large buffer. Full is around 82% actual state of charge so it’s ok to fully charge every day.
    If you’re travelling and leaving the car parked, I believe the manual states to leave the battery “empty” and the car in hybrid (HV) mode.
