2018 PRius Prime TPMS Sensor
Discussion in 'Prime Main Forum (2017-2022)' started by richard203, Aug 8, 2026.
  1. richard203
    richard203 Member
    284
    61
    SF
    Hi I was wondering do the prius prime have tpms sensor? when I change out my rims and tires i ask the shop to transfer the tpms to the new rim and they call me back and say theres no sensor on the old rim. When I got back my car no tpms light is on. o.0
    shop took a picture of it
    #1 richard203, Aug 8, 2026
  2. rjparker
    11,124
    6,979
    Odds are good somebody previously disabled the car's tpms system. Or the tire shop broke one or more sensors.
    The owners manual suggests it could take 20 minutes to alarm if the sensors are not reporting after a startup. Tpms is required by law and Toyota uses sensors.
    Toyota oem 315mhz sensors look like this
    There are aftermarket sensors for $40 a set on Amazon but the new ids have to be written into the Tpms ecu with a scanner or specialized Autel tpms tool.
    There are also configurable id Autel MX sensors which can be set to existing sensor ids. Those can be read from the tpms ecu.
    If you only need one its $28. Autel MX sensors require an Autel tpms tool like a TS408s or similar to configure the Mx sensor's id.
    Autel Mx sensors have a quick connect button on the inside part and will break if pulled out. Regular oem and aftermarket sensors are one piece and use a retaining nut.
    Autel Mx sensors are often used by tire shops because they are universal 315mhz or 433 mhz and setup for various protocols.
    Disable tpms ecu with jumper
    (gen3 but gen4 may be the same)
    #2 rjparker, Aug 8, 2026
  3. richard203
    richard203 Member
    284
    61
    SF
    been driving for 1 whole day already, no tpms light on. how do I know if they disabled the tpms system? I thought tpms system cant be disabled.
  4. rjparker
    11,124
    6,979
    See previous post's attachment
  5. richard203
    richard203 Member
    284
    61
    SF
    thanks will check that hopefully the previous owner didn't do that. ><
    you know any good aftermarket tpms sensor for the prius prime? I know you say auteI sensor but I gotta buy the scanner. I got tech stream and dont wanna go oem route any aftermarket that works like oem or oe?
  6. rjparker
    11,124
    6,979
    You search for Toyota tpms sensor for your car.
    An aftermarket set that sells well
    This one has a coupon reducing the set to $34. They have factory set ids which can be written to the tpms ecu with Techstream.
    But first you need to figure out your current situation. It is either tpms disabled or you have tpms sensors. I would check the tpms ecu with Techstream.
    #6 rjparker, Aug 9, 2026 at 11:57 AM
  7. richard203
    richard203 Member
    284
    61
    SF
    ya i'll post an update if it got disabled or not. do you by chance know the denso part number for this car? I tried researching for the denso part number but no go
    #7 richard203, Aug 9, 2026 at 11:40 PM
  8. Autoknown
    Autoknown New Member
    Europé
    2020 Prius PHV
    Many systems disable the check if the ID is 0000000
  9. rjparker
    11,124
    6,979
    I am pretty sure the Toyota system will reject ids of 000000 and still trigger the tpms light.
    It would certainly be worth checking to see what is in the data.
    However it seems gen4 does not have a simple jumper trick available due to the tpms ecu becoming a can bus module.
    Apparently there is a method to fake out the system:
    "Pipe Bomb" Method (No Vehicle Modifications)
    This is the preferred physical bypass method used by Prius owners who run aftermarket wheels or winter tires without sensors. It leaves the car's computer completely stock:
    • The Concept: Buy a cheap set of 4 programmable or compatible Toyota TPMS sensors.
    • The Build: Take a small piece of PVC pipe, cap both ends, install a standard tire valve stem, and place all 4 sensors loose inside the pipe.
    • The Execution: Pressurize the PVC pipe to 36 PSI (the standard front tire spec for your Prius Prime). Program these 4 sensor IDs into your car's computer, then toss the pressurized pipe into the trunk or spare tire well.
    • The Result: The car continuously reads the steady 36 PSI from the trunk, and the dashboard light stays off permanently.
    #9 rjparker, Aug 10, 2026 at 10:21 AM
    Autoknown likes this.
  10. BiomedO1
    4,630
    2,427
    Left Coast
    That looks like a steel rim; I though that ALL Primes came with aluminum rims and the chinchy plastic wheel covers. You must've bought that car used.
    When you turn-on the car; your TPMS lamp should light-up temporary; part of the power-up systems check (flat tire symbol in the middle of your warning symbol cluster).
  11. Autoknown
    Europé
    2020 Prius PHV
    @BiomedO1 Only US models had the lame plastic covers.
    @rjparker Interesting work around that I tried before with a lame pressure bottle with all sensors in it... it leaked slowly. The concept mentioned may work better, but seal leaks are likely with that pressure.
    Try to enter 0000000 (seven zeros) for any ID - empirical evidence is more useful. Every Toyota has this ID for that spare tire. So swap that ID, duplicates are not allowed.
    I would never recommend it though. Clonable ID is the smart way. I have used thinkcar S3 sensors for ten years and they are superb.
    #11 Autoknown, Aug 10, 2026 at 3:34 PM
  12. richard203
    richard203 Member
    284
    61
    SF
    some prius prime have steel rim no plastic cover. People say its the 2nd package that come with steel rim. I brought the car used. Now its time to change tires and this is what the tire shop told me.
    Heres what my rim look like
    https://parts.elmhursttoyota.com/oem-parts/toyota-genuine-toyota-2016-and-newer-prius-15-quot-10-spoke-alloy-wheel-pt94547160?origin=pla&utm_source=google&utm_medium=cpc&adtype=pla&utm_id=23481614780&utm_adgroupid=188844602581&utm_targetid=pla-396691255607&utm_matchtype=&utm_network=g&utm_device=c&utm_term=&utm_campaign=RP_Toyota_Shopping_Parts_Accessories_Max_TROAS&gad_source=1&gad_campaignid=23481614780&gclid=Cj0KCQjw7eXTBhDBARIsAKF-w47TyT_nVw_TSuXuaIu1exnUdbQqvVLfmJzvyvBa2FKGKy-kSllcLd4aApiSEALw_wcB
  13. rjparker
    11,124
    6,979
    Actually all three Prius Prime versions came with the same aluminum alloy wheels.
    All of them came with tpms sensors. A tpms system is required by federal law.
    Somebody swapped the oem wheels for steel wheels.
    BiomedO1 likes this.
  14. BiomedO1
    4,630
    2,427
    Left Coast
    And the shop that did that, didn't move the sensors - and bypass them.
    The picture you posted looks like a steel rim. I haven't seen Toyota alloy rims painted black inside the wheel mounting area - eternally yes, but internally NO.
    #14 BiomedO1, Aug 11, 2026 at 9:20 AM
  15. Autoknown
    Europé
    2020 Prius PHV
    Came with? What does that mean? If you could downgrade to save cost, most were likely sold with steel rims..
  16. rjparker
    11,124
    6,979
    In the US (op is in California) all Prius Primes were sold with aluminum wheels and tpms sensors.
    The wheels he is buying now were the upgrade.
    See the accessory and product brochure I attached above.
  17. Autoknown
    Europé
    2020 Prius PHV
    @rjparker But with a hub cap - apparently. Not steel wheels though.
    Are these removable, otherwise it’s not really hub caps imho.
    #17 Autoknown, Aug 15, 2026 at 7:44 AM
  18. rjparker
    11,124
    6,979
    Yes Prius had removable hub caps to show off the aluminum wheels or had plastic wheel covers to provide improved aerodynamics. Many removed the wheel covers and added the center hub cap.
    Aerodynamics was a big thing with Prius to achieve the best mpg. Wheel covers, wiper blades, body flares, rear spoiler, body shape, etc.
    Pics extracted from attachments above to aid comprehension
    #18 rjparker, Aug 15, 2026 at 8:38 AM
