2025 Unplugged Valve Cover Vents??
Discussion in 'Gen 5 Prius Main Forum' started by SXP, Jul 26, 2026.
  1. SXP
    SXP Junior Member
    Huntington Beach, Ca
    2025 Prius
    Could someone look under their hood and see if these three "vents" are supposed to be open to the atmosphere, or should they have hoses or plugs connected to them. Thanks. PXL_20260726_233228497.jpg
  2. ChapmanF
    19,045
    Are those the standoffs for a decorative cover that sits on top of the engine, that might be missing on yours?
    Brian1954 likes this.
  3. Hammersmith
    Hammersmith Senior Member
    2,497
    2,555
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Those are indeed the places where an engine cover goes. The cover has rubber rings that hold onto those tubes. But the M20A in the Prius sits too far under the cowl for any engine cover to fit. The only M20A I found that uses a cover is the Lexus UX series.
    Back in 2023 when I bought my gen5, I ordered one to see if it would fit. If it had, I was going to modify it a bit to remove the Lexus badging and replace it with Toyota badging. But it only took a few minutes to realize the plans were futile.
    There are only three connection points, and one is right under a heat shield(the one in OP's first photo). There's no way to modify the engine cover to fit without removing that connection entirely. And the cover wouldn't be stable with only two connection points. So now I've got a UX 200 engine cover sitting on a shelf in my garage for the last three years. lol
    As for why the Prius(and Corolla) valve cover has points for a engine cover it doesn't have, it's because it's cheaper to just make a single part that works on all M20A engines.
    This is what the M20A in a UX looks like:
    I bought a UX 200 cover that didn't have the hybrid badge. I planned to paint the whole thing one or two shades of matte black for more of a Toyota look, and I was going to pry or grind off the Lexus L and find a chromed Toyota T logo of about the same size and glue it on.
    I believe it was the gen3 where you could dress up the engine bay with parts from Toyota Japan as well as some parts from the Lexus CT(OEM hood struts, coolant tank covers, engine cover, etc.). I was hoping to do something similar to my gen5, but the spaces are just too tight.
    #3 Hammersmith, Jul 27, 2026
  4. PriusCamper
    PriusCamper Senior Member
    13,471
    5,438
    Pacific Northwest, USA
    I heard there's lots of different super expensive Legos Minifigs that fit on 'em...
  5. SXP
    SXP Junior Member
    2025 Prius
    Thanks guys. I guess I could have stuck a screwdriver down one of the tubes to see if it passed through or not....
  6. ChapmanF
    19,045
    It does, if you stick the screwdriver down hard enough. :D
    QAH254 and Mendel Leisk like this.
  7. Mendel Leisk
    42,365
    You’re not the first to ask btw. If cover is missing, or not used, it does look odd.
  8. Analogkid1958
    Analogkid1958 Member
    123
    61
    Yorktown, IN
    2024 Prius
    ...and honestly, why add more weight to a car that is designed around efficiency? A fair bit of weight must have been added to stiffen the car, and the safety components add some weight, but those are net benefits. Pretty geegaws under the hood, not so much. :)
  9. Mendel Leisk
    42,365
    I opted for one bitty cover, over some fragile-looking, exposed ECM wires. Seems like they should been covered at the factory; really looks like something missing. There's an existing lever arm there, for the cover, but no cover.
    All that other malarkey, I'll pass.
  10. ChapmanF
    19,045
    The lever holds that connector in, and helps you unplug/replug it, cover or no.
  11. Hammersmith
    2,497
    2,555
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    It's a choice. Right or wrong is up to the individual and their priorities. It brings some people pleasure for their things to look good, and it brings other people pleasure to squeeze every bit of mpg out of their car that they can. Both are okay.
    I think the engine cover weighs maybe a pound, so I would have been fine with that 0.001mpg loss if it made my engine bay look a little tidier. But I absolutely wouldn't fault people for not doing the same. Same for using the parts from a Lexus CT200h to slightly dress up a gen3. For some of us, our brains get a little hit of serotonin when things look "just right". That's what stuff like this falls under.
    Analogkid1958 likes this.
  12. Analogkid1958
    123
    61
    Yorktown, IN
    2024 Prius
    I agree in reality. I like my car to look as good as possible, so I did add the mud guards, which likely weigh more than any engine cover.
    It's all about tradeoffs!!
  13. SXP
    SXP Junior Member
    2025 Prius
    OEM? Pics and a link please.
  14. Analogkid1958
    123
    61
    Yorktown, IN
    2024 Prius
    2023-2026 Toyota Mudguards - Black PK389-47R00-TP | American Toyota Parts https://share.google/Jq6VLEOEukKoBjaHs
    Installed by the dealer about $150. They do decent job of keeping the worst off of the body.
  15. Mendel Leisk
    42,365
    I used to always get mud flaps, then didn't. One issue, while they maybe deflect rocks, they also tend to trap muck in behind.
  16. Hammersmith
    2,497
    2,555
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Not a big deal on the current gen. It's all plastic on plastic down there. I've had mine off a few times and the worst is a little grit that gets into the plastic clips and makes them a bit hard to get out. If I'm smart, I remember to grab some detail spray to flush them out before removing them(always a good technique when removing clips on the outside of the car). Otherwise I just force them.
  17. Mendel Leisk
    42,365
    With our Hondas over the years, mud flaps were always secured by coarse-thread screws into nylon embeds.
