Dash ABS/VSC light?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AJP, Aug 17, 2026 at 4:55 PM.
  1. AJP
    AJP Member
    161
    Central Pennsylvania
    Had my left front wheel bearing replaced last week and suddenly I'm getting the ((!)) ABS VSC light anytime my RIGHT front wheel goes over even a tiny bump. My OBD reader was throwing a bunch of brake codes but I cleared them and ran them again and nothing came up. I know my brake actuator is starting to bleed off a bit but I don't know if that's related. 12v is reading fine.
    2007
    215,000 miles
    If needed, here were the codes. Either weeks ago I had the brakes bled and a pin unstuck.
    C0200- RF sensor
    C0205 - LF sensor
    C1235 - LF debris
    C1245 - Foreign Object Attached on Tip of Front Speed Sensor RH (Right Front)" or a signal disturbance from the right front wheel speed sensor
    C1253 - Hydro pump motor relay malfunction
    C1256 - Low accumulator pressure
  2. PriusCamper
    PriusCamper Senior Member
    13,472
    5,439
    Pacific Northwest, USA
    Isn't the person who did your wheelbearing responsible for this situation? Or at least as a first step can you take it back to them and communicate this information?
    GLCReviews likes this.
  3. GLCReviews
    GLCReviews New Member
    17
    2014 Prius Plug-in
    I would take it back to them and have them check the wiring harness from the ABS speed sensor at the hub/bearing assembly and make sure it's not damaged or any wires frayed. If it's intermittent, perhaps something minor and they should replace or fix it.
