Nav Question
Discussion in 'Gen 2 Prius Main Forum' started by Rest, Feb 7, 2007.
  1. Rest
    Rest Active Member
    1,210
    CA
    I've tried searching and can't find the answer. Is there a way to see the approaching next street with the Prius GPS Nav system? Most cheaper handheld units do this.
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I think if you zoom in all the way it should display the street at the top of the screen.
  3. Rest
    Rest Active Member
    1,210
    CA
    Yes it displays the street you are on. That is not what I want. I want to see the next upcoming cross street.
  4. clifford
    clifford Member
    156
    <div class='quotetop'>QUOTE(Rest @ Feb 7 2007, 11:12 PM) [snapback]386798[/snapback]</div>
    Yes you are correct. This nav is not as good as a cheaper gps like Garmin.
  5. Rest
    Rest Active Member
    1,210
    CA
    yea well...thanks for that.
  6. Tripod137
    Tripod137 New Member
    145
    Long Island
    Zooming in all the way down to 300ft(175?) doesn't give you the street names?
  7. cireecnop1
    cireecnop1 New Member
    338
    Pueblo, CO
    I'm not sure since I just got my car, but dont you have to select that Icon that shows the exits on the highway or no? are you just talking about the general gps screen and not when its in guidance mode?
  8. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
  9. hill
    8,910
    I'm thinking that even @ 300' display, the next street won't necessarily display if it' just a little 2 lane jobbie that you are approaching. However, if you TOUCH the screen on that street ... it WILL display it's name up on the header of the display.
