Hi all, I just want to know if 44510-47051 abs actuator is compatible with 44510-47050 actuator for Japanese spec gen 2 prius. I have heard that the 051 abs actuator is the revised actuator which is the one to get but just want to know if it will work on a Japanese spec car that has the the 050 actuator, looking online people say it's compatible but no one has asked if will work specifically for the Japanese spec. I assume it will work just fine cause the part number is the same for all different regions.
