Had my left front wheel bearing replaced last week and suddenly I'm getting the ((!)) ABS VSC light anytime my RIGHT front wheel goes over even a tiny bump. My OBD reader was throwing a bunch of brake codes but I cleared them and ran them again and nothing came up. I know my brake actuator is starting to bleed off a bit but I don't know if that's related. 12v is reading fine. 2007 215,000 miles If needed, here were the codes. Either weeks ago I had the brakes bled and a pin unstuck. C0200- RF sensor C0205 - LF sensor C1235 - LF debris C1245 - Foreign Object Attached on Tip of Front Speed Sensor RH (Right Front)" or a signal disturbance from the right front wheel speed sensor C1253 - Hydro pump motor relay malfunction C1256 - Low accumulator pressure
Isn't the person who did your wheelbearing responsible for this situation? Or at least as a first step can you take it back to them and communicate this information?
I would take it back to them and have them check the wiring harness from the ABS speed sensor at the hub/bearing assembly and make sure it's not damaged or any wires frayed. If it's intermittent, perhaps something minor and they should replace or fix it.
Or just get under the car and take a look real quick but look at your codes there he did not create all those . Even on car change out usually has sensor out of aluminum.hub assy.e en it just hanging .
